Turbo tie rod spacers help
Hi all,
I just had tie rods put on an 85 coupe and had a shop do the install and then an alignment. I purchased the parts intending to put them on myself but ran out of time so gave the shop my parts bags from Pelican and away we went. Go the car back and it seemed a bit more responsive but who knows. I did notice in the wheel well a scuff wear one would expect to see tire rub. I thought maybe it was there before but was not sure. I have stock 6 and 7" Fuchs on with SO2's, stock sizes. Then came the big uh oh. TIdying up the garage, I found a bag with the two spacers in it. I am going to call the shop and ask if they install another set of spacers but I doubt it. I didn't see them on the invoice. I have two questions. Can I track it this weekend? Just a couple of hours planned on a Friday night, not the whole weekend. Second question. Can I just remove the tie rod from the rack end and put them in, followed by another #$@#$# alignment or do I need to redo the install from scratch? Thanks, Lawrence
1985 911 Coupe Black 1985 911 Cab GP White (killed) |
Ruby911
Since you reference spacers, I assume you had turbo tire rods put in. You are not going to be able to remove the inner portion of the tierod without removing the outer portion from the steering arm (maybe you can if they are not turbo tie rods, you would have to uncsrew the inner adjustment until it came apart, but I am not sure you would have enought to hold on to to loosen the inner section attached to the steering rack). Once you remove it and install the spacers (assuming they are not already there), you will, in effect, have increased the length of the tierod, creating toe in. Long story short, sounds like you might be starting over.
As far as tracking the car, I am not sure if it is a problem, but it would be a bigger gamble than I (personally) would want to take.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
Thanks Ruby. They are turbo tie rods.
What waste of money. My fault I guess.
Ruby911
Double check with the shop before you do anything. My understanding (which may be wrong) is the turbo tie rods will not seat all the way on the steering wrack without those spacers. I would think that the shop would notice this. Good luck.
while I'm in there...
Well since I am going to have to start over again, while I'm in there...?
Would it be worth doing something else? New shocks? New ball joints? Bushings looked OK last time I looked.
Ruby911
Double check with the shop before you do anything. My understanding (which may be wrong) is the shoulder on the turbo tie rods will not seat all the way on the steering rack without those spacers (the threaded bolt will bottom out). I would think that the shop would notice this. Good luck.
Ruby911
The tierod job does not invlove touching the shocks or ball joints - so I would only replace them if they were showing symptoms of being worn out.
How long to install Turbo Tie Rods?
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
