Question spark plug gap question
What are the effects of having a plug gap that is larger than the factory spec? Will it run leaner?
Old 12-10-2001, 09:50 PM
PRO Motorsports
Tyson Schmidt's Avatar
It won't make your car run richer or leaner. If your ignition system isn't up to the task, you will have misfires.
Aftermarket ignition systems that deliver a hotter spark, recommend wider gaps for a larger spark kernel. This is to take advantage of the higher voltage available from the aftermarket CD unit/coil.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 12-10-2001, 11:35 PM
