Question got some H4's, but...
Hi everyone!
I recently purchased the H4 upgrade for my '81SC here at Pelican - but two of the retaining screws for one of the headlights are stripped (well, the threads are ok I think, but my phillips can't fit in to the grooves on the head - the metal is really soft - so now there is a big circular hole in the screw head) - i'm wondering if any of you have any tips on getting these screws out???
Thanks,
Dylan Essner
1979 911SC
silver/lobster red
Old 12-12-2001, 02:00 PM
Senior Member
Superman's Avatar
American ingenuity. Sadly, there are jobs that a good hammer still won't perform. I'd consider needle nosed pliers or a reverse-threaded drill bit.
Mocha 1978 911SC. "Coco"
Old 12-12-2001, 02:08 PM
Superman's choice of a left-handed drill bit is my choice as well.
Lacking this, use a large-enough drill bit to drill through to remove the Phillips head. Once the headlight assembly is off, use needle-nose pliers to remove the remaining portion of the screw.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 12-12-2001, 02:17 PM
