E Sully's Avatar
Center Cap Protection?
How do you protect your 3 prong Fuchs center caps from theft?
Ed
1973.5 T
Old 05-05-2010, 04:35 PM
80-911SC's Avatar
never let your car leave your site ... and have your wife watch the other side when you cant park in the garage..............'
Old 05-05-2010, 06:21 PM
Senior Advisor
James Brown's Avatar
how about drilling 3 holes in the ring and taping them for a set screw. you can drill small dimples in the wheel to further secure them. Might not totally keep them on if someone is prying on them but could deter a casual thief.
08 Cayenne Turbo
Old 05-06-2010, 03:53 PM
Recreational User
porschenut's Avatar
.45 acp
Old 05-06-2010, 03:56 PM
You can cut a disk, to the diameter of the underside lip of the cap, from thin plywood or some other thin, rigid material. Notch the disk for a snug fit against the three prong arms and insert it from the backside of the wheel, once the cap is installed. The disk will prevent the prongs from compressing. Loop a piece of soft wire around each prong to keep the disk in place. Now, the caps can only be removed once the wheel is off the car.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 05-06-2010, 06:19 PM
