nineball's Avatar
scissor lift question
finally going to be joining the club later this week and i have a question. the various owners manuals i have read all seem to say the same thing - that the engine should be in the rear of the lift. since we are reversed should i put the lift backwards in the garage? looking it over i would think that i would want the end with the two cylinders to be under the front of the car for increased access to the engine, right?
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 05-02-2010, 06:55 AM
Confused
That's how I use mine - Hydraulics under the nose - I do try to keep the rear arms at 90 degrees to the lift though, and the car fairly forward on the lift - Seems fine.
Squeaky brakes are safer....
2000 GT3 Clubsport, 1967 911 2.7 Track toy in progress
1983 Lamborghini Countach 5000S, 2009 VW Tuareg, 6 Bicycles - 3 Road, 3 Mountain
Old 05-02-2010, 12:18 PM
80 911 SC, Orem, Ut
RSWiser's Avatar
I like your ramps.
Did you buy those or make them.
Rob
1980 911 SC
Old 05-02-2010, 12:44 PM
Confused
I was going to make them, but wanted them in a hurry and was crazy busy at work - got a mate to make them in the end. They are great, but really take 2 people to move them around, as they weight about 150 pounds each - so I plan to make some mods to enable them to be moved more easily, as well as cutouts that will take corner balance scales that can be individually levelled - its just a question of available time.
Old 05-02-2010, 12:55 PM
nineball's Avatar
got the lift delivered this evening but my phone camera cannot take a pic worth a damn when it's dark so pics will come tomorrow. i never really thought of 48" as being high until i saw the platform at it's max height. the only problem, if you want to call it that, is that there is a bar welded between the rails on the back of the lift. it looks like it may make dropping the engine impossible. luckily i already did that in the fall on a friend's 2 post and did what i needed to but for the future i may have to cut that bar out.
Old 05-04-2010, 06:16 PM
356RS's Avatar
The problem I see with V12man's lift position are the hydraulics at the front of the car. Most of the weight with a Porsche is at the rear, so as the scissors style lift goes up the rear legs with the rollers get closer to the center of the car and all that weight at the rear makes the lift very tail heavy. Not all the scissor style lifts are the same, and V12man's looks well built, but just a word of caution.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-05-2010, 07:32 AM
Carrera Cab Connoisseur
nyne11's Avatar
No problem with mine jacking at normal points....enjoy.
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 05-07-2010, 06:12 AM
Bill Verburg's Avatar
Not so, the lift should have it's ctr marked, on mine the yellow sticker has the ctr pt marked by the circle w/ black quadrants. you want the center of mass of the car near that point on the lift. On a 911 the CoM is near the factory lift point(black plastic cover on the sill)
Bill Verburg
Old 05-07-2010, 06:20 AM
