Tap case for SSI install?
Just getting around to fitting everything up and there are these two tabs on the SSI's that look like they call to be bolted down but there's no holes tapped in the case to bolt them down. Did I miss something along the lines of install research? I don't recall ever reading that someone had to tap the case to install SSI's. If so, are the 6 or 8mm?
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 05-10-2010, 09:39 AM
Information Junky
island911's Avatar
Weird that those case flanges aren't already drilled & tapped.
go for it.
edit: I expect that it's a 6mm.
Old 05-10-2010, 09:46 AM
Band.
I think there's usually a short M6 stud right there, and you put a nut and a lock washer on it.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 05-10-2010, 10:11 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
Mine had a tapped hole there already (not a stud). That is strange. M6 sounds correct.
Come to think of it, I had to re-drill the tab on the SSIs because the hole didn't line up with the case.
1981 SC ROW Coupe
Old 05-10-2010, 10:18 AM
East Coast R Gruppe
mike monde's Avatar
Mickey,
projected finish date?
OGRP3
RGRPNE
Old 05-10-2010, 10:21 AM
Bill Verburg's Avatar
Don't bother, they aren't necessary.
Bill Verburg
E Sully's Avatar
My '86 3.2 has no hole or stud either. I was also wondering if I should drill and tap for the SSI's.
Ed
1973.5 T
Old 05-10-2010, 10:23 AM
disband
juanbenae's Avatar
mine did not line up well enough to use so i left em empty. not much there to warrent drilling into the case i reckon.
Old 05-10-2010, 10:27 AM
Scott R's Avatar
If you want those to line up you need to slacken the barrel nuts on the pipes to the heads get those bolts installed and tighten everything up. I had the same issue, however I'm that guy that can't stand missing nuts and bolts so I went back in a fixed it. I doubt as mentioned above that they actually do anything however.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-10-2010, 10:41 AM
I guess I'll leave them alone. The area is very accessible so I can do it later if there it too much vibration.
Hoping to have it back in by the weekend. Replacing Vacuum lines and CIS stuff today and tomorrow and I should be good to go.
Old 05-10-2010, 10:42 AM
My '84 didn't have bolt holes for them either. I just left the tabs blowing in the breeze - no problems so far.
Charles
'84 911 3.2
Old 05-10-2010, 11:16 AM
grateful user
don gilbert's Avatar
I drilled and tapped mine. Being such a big expence, I think it is good insurance againt vibrating any welds loose and having a rattle.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 05-10-2010, 11:48 AM
brads911sc's Avatar
mine weren't drilled either...
i didnt use them...
go for it.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 05-10-2010, 12:11 PM
wesayso's Avatar
I drilled and tapped them and put in M6 studs... Fit is perfect due to being able to do the drilling after a trail fit of the SSI's
'82 911 SC
Old 05-10-2010, 01:19 PM
