Mike Holbrook
Brake light now on. Loose connection?
I have been working around under the dash for a couple weeks now getting a new stereo installed. Everything is in and works fine and a couple days ago the brake light (under the seat belt light) by the ash tray comes on and won't go out.
In the past, this indicated that the hand brake was not fully down. Now it won't go off. I can't see a microswitch around the hand brake so I guess it must be under the car? Could I have bumped a connection which might have caused the light to stay on. The hand brake works properly and is not dragging and does stop the car well. I can feel it working correctly on both sides so I don't think there is a fault in the brake. The tail lights also seem to be working correctly. Brake and tail lights. Any suggestions would be appreciated.
Mike Holbrook Meridian, ID 1979 911SC Targa |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Recreational User
Try disconnecting the battery ground cable for a few minutes, then reconnect. This is the typical procedure to extinguish the light. It just needs a reset. Of course, if that doesn't work, the switch would be the likely culprit.
Search on here. There are many posts about this, including the switches on the master cylinder. I gave up and disconnected the light.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
E-Brake light.
Here are the schematics for the '84 (Bentley), and the '86 (factory manual).
Hope it helps. And please let the members know. Good luck, Gerry ![]()
winter
I'm sure you've already checked, but is your brake fluid level correct? Not familiar with your car, so maybe you have a different light to alert you to that, but thought I'd throw it out there just in case the problem isn't related to the install you did, and just happened - coincidentally - at the same time.
Good luck. --- Tom '75 targa |
