Woodyhfd's Avatar
Did I drive through grease or do I have an A/C problem?
I just finished washing my 1987 911 and I noticed that the driver's side rocker panel behind the front wheel was covered with grease. At first I thought I drove through a blob of grease on the road, but when I looked up under the wheel well and saw that the A/C dryer was covered, I started to wonder if it's an A/C oil leak or something else. It may have just been thrown up there by the wheel.
I had the A/C on last week, but mostly for the fan.
Any suggestions?
1987 911 Coupe, Diamond Blue Metallic
2006 Cayman S, Seal Gray
1983 911 Targa, Black: The Dirty 911 (GRM)
Old 05-11-2010, 01:48 PM
Clean everything well with an oil cutting, biodegradable product, dry it thoroughly, and go for a drive with the AC on. Or, clean it up and simply run the AC and see if you see oil seepage while the system is on.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 05-11-2010, 05:45 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
if you didn't you do......
The oil seems to be from the AC system. An AC charge contains the refrigerant and a small amount of oil to lubricate the moving compressor parts. Maybe some shop did a sloppy job before and didn't clean up. Else you have a leak.
Normally, with a leak the refrigerant goes first and the compressor won't even come on because the system pressure is too low. However, a conclusive test is to clean the area and then watch it. You might want to buy a dye or have a shop charge the system with a dye to spot tiny leaks. The dye is contains UV-active components and will glow when illuminated with an alternate ligth source. (UV lamp).
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-11-2010, 10:12 PM
Woodyhfd's Avatar
It looked to be some kind of blue grease. If it's coming from the A/C system, I may just remove it all and be done with it.
Unfortunately, hand surgery this morning is going to delay any more work for a while.
In the mean time, any other info is appreciated.
Old 05-12-2010, 10:48 AM
Does the AC get cold now? See any bubbles in the sight glass? With it running you might can see any leak that splattered that much oil.
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 05-12-2010, 11:16 AM
Woodyhfd's Avatar
It never really got super cold to begin with.
Old 05-12-2010, 11:20 AM
