-   -   Broken Thermostat already? (http://forums.pelicanparts.com/porsche-911-technical-forum/542078-broken-thermostat-already.html)
fintstone 05-22-2010 10:48 PM
Originally Posted by boyt911sc (Post 5351072)
Grant,
Thanks for the information. And I've sent a PM to Walt asking for some clarification about the 'wax' like device too. I was curious how these auxiliary thermostat work and have dis-assembled a few of them to investigate and study their function.
Walt,
Please accept my apology for contradicting your statement. I have not seen the wax-like material in the auxiliary thermostat during my quests and would dissect the valve next time I get the chance.
Tony
The part with the wax in it is just to the right of the spring in your photos. It is the piston in a sleeve. Walt is absolutely correct.
fintstone 05-22-2010 10:49 PM
Otto
Make sure that your temp sender matches your gauge, not necessarily your engine. If it was correct with your 3.0, then that is the sender you need.
otto in norway 05-27-2010 02:08 PM
Thanks for all your input.
I have finally got some time at home to investigate further.
I purchased a electronic steak thermometer for use when determining the temp of food. But I had other intentions for it. I just put the meter pin right down into the oil tank when I had warmed it up a bit. When the temperature reached 88 celsius, I felt the pipes going to the front heat up. So, the external thermostat works after all. I then checked the part number for my new temperature sender. It turns out I have the wrong sender. I have the one for numbered gauges, not for my gauge without numbers on it.
So that was good news! :)
I just need to replace the sender, -a walk in the park... :cool:
