Help!
No start and I'm not close to home. Got juice. When I turn the key I hear a buzz like the windshield washers. What should I look at?
Old 05-12-2010, 08:09 PM
AutoBahned
RWebb's Avatar
what happens when you turn the headlights on?
what happens when you turn the headlights on & try the starter?
what car is it?
Old 05-12-2010, 08:15 PM
83 sc lights work. When I hit starter with lights on lights go off.
Old 05-12-2010, 08:16 PM
AutoBahned
RWebb's Avatar
measure battery voltage w/o load using multimeter
Old 05-12-2010, 08:34 PM
No multimeter. Just turned the key again. Nothing. Turned it again and it fired right up. Heading home. Will look at battery there. Thanks rwebb.
Old 05-12-2010, 08:37 PM
Loose/dirty battery connection?
Old 05-12-2010, 10:12 PM
Gents, I made it home. The car started up, I drove 60 miles home, parked it in the garage, shut it down, tried to start it again and it just hummed like before.
The battery is only a few months old. (PO installed it shortly before selling the car.) Terminals are clean. Voltage measures 12.6 w/out load. I'm going to dig around the forum. Any help is greatly appreciated. Thanks for your concern.
1983 SC
Blog
Old 05-12-2010, 10:29 PM
muck-raker
kidrock's Avatar
Starter motor may have bad or dirty connections, or got overheated. I bet it starts this morning.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-13-2010, 02:01 AM
Almost Banned Once
sc_rufctr's Avatar
x2... That's the first thing that came to mind when I read the thread.
- Peter
Old 05-13-2010, 02:28 AM
Kid and SC, after reading around, that's what I'm thinking, too. The cable on the negative battery cable was a little loose, though not loose enough to come off. I put the battery on the charger overnight just for fun. This morning I reconnected the battery cables, and it fired right up. Drove it on country roads for 30 minutes to get it up to temp. Parked it in the garage. Shut it down. Started it. Repeated. Seems to be able to start when warm, maybe just not when hot. (I had been driving it pretty hard last night.) I'm going to check the connections on the starter to make sure they're clean and I guess just see if this becomes a recurring issue. Thanks for your input.
1983 SC
Blog
Old 05-13-2010, 09:25 AM
GothingNC's Avatar
I had the same thing happen with a loose/dirty negative battery connection
Turn the key, hear a slight buzz then nothing.
On my old VW, I used to tap the battery terminals with a hammer
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 05-13-2010, 09:31 AM
AutoBahned
RWebb's Avatar
you have a bad battery - if leads put on properly for the no load test then should read a LOT higher
take to Autozone or similar & have them test it using a Load Tester
get it replaced if at all marginal
while it is out:
examine, derust & repair all cables on starter terminals
also examine neg. cable & trans. to body gnd. strap - treat them to a derusting
can't be the ignition switch or there'd be no sound
solenoid problem usually causes clicking; slight chance it is damaged in some other way
Old 05-13-2010, 02:45 PM
My no load test consisted of sticking the multimeter leads on the battery terminals. What's a healthy battery read?
Cables and grounds look great.
Old 05-13-2010, 04:34 PM
ShakinJoe's Avatar
Over 12 volts.
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 05-13-2010, 04:54 PM
Hence my confusion about rwebb's comment about the bad battery. I thought 12.6 would be considered fine.
Old 05-13-2010, 05:02 PM
crustychief's Avatar
It could read that with a weak cell, as soon as you hit the key it would go below 9 volts.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 05-13-2010, 05:07 PM
Was the engine running at 12.6V? That would be too low; should be 13.5-14.9.
If not, it's OK.
Take it to the store and have them do a battery load test.
Old 05-13-2010, 05:20 PM
12.6 with engine off. I'll try with the motor running and take it in for load testing, too.
Old 05-13-2010, 05:35 PM
Followup: I have not had the battery load tested yet. I did clean the grounds from battery to body and from transmission to body as well as all the leads to the starter, all with sandpaper, wire brushes, wd40, rags. Drove the car hard for a couple hours tonight, and the restarting problem was not apparent. In fact, it sounded great starting up. I realize this may be only a temporary fix.
That said, I tested the voltage again:
motor off: 12.6
at idle after driving: 12.7
Is this low? If so, too low?
1983 SC
Blog
Old 05-18-2010, 10:48 PM
TibetanT's Avatar
Hello There:
I am certainly not an expert, but I can tell you that when my 1983 911SC is idling she is putting out 13.6 volts at the battery terminals with multimeter reading. Then, after driving for a while, reading at battery terminals with engine shut off reads about 12.86 volts.
Could it be you are not getting enough current from your alternator?
But, now that I am thinking about it, driving your car around for an hour would charge the battery. Hmmm?
Like someone said earlier, check your cells inside the battery...maybe one is low. I know here in the Northwest during the Winter months the air gets very dry and the battery cells loose their fluids.
Just a thought. I hope this helps. Good luck.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 05-18-2010, 11:32 PM
