1975 911 fog light wiring
The wiring to my fog lights is not factory. Does anyone have photos that shoe how it should be installed?
As in is there a psir of wires in the headlight bucket that is used for the fog lights? |
ROW '78 911 Targa
Not in 74 and newer. Run inside the front of trunk to where the fog lamps are. Then connect through holes and grommets to the fog lamp wires.
I need to re-examine how they were installed.
I take it the fog lights you have are factory and the pull switch that operates them is also factory?
I don’t have the factory wiring diagram. Factory power wires to fuse panel are white/yellow stripe and brown. Wires route from panel to lights thru grommets, terminal connector runs along under trunk header to the passenger side. Here’s a pic of what Timmy2 stated how wires are routed. (If you need any other particular photos elsewhere let me know while my trunk is open)
I checked, mine penetrate in one place on the drivers side then they run wires across the inside of the front valence to the passenger side, very slap dash, I think they are shorted somewhere as they appear to draw too much current.
thanks
1975 911S Targa Silver Anniversary Edition |
