Pool Acid (muriatic) to Clean/Prepare Caliper for Paint...
Caliper is off the car and being rebuilt. Wondering if this would work as an easy prep to paint. Thanx in advance for your help!
Old 05-23-2010, 09:52 AM
I used spray brake cleaner and wire brush. Which did a very good job.
Muriatic acid is really gnarly and toxic. lots of fumes, need to wear respirator etc.
Be carefull
Richard
Old 05-23-2010, 11:30 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Muratic, very poor choice! Will destroy aluminum, and pit steel alloy. Use it for your pool or oil stains on the driveway.
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 05-23-2010, 11:51 AM
Easily Confused
dtxscott's Avatar
If you want to use an aggressive solvent, Kerosene does a good job and cleans up easily.
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 05-23-2010, 12:10 PM
Under the radar
Trackrash's Avatar
If there is some rust or corrosion a good product is something like Prep and Prime, which is a solution of phosphoric acid. Available at most paint stores it will clean and remove rust. Unlike pool acid it will not harm steel or aluminum.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-23-2010, 02:06 PM
Oven cleaner works really well. Destroys grease and baked on grime. Then rinse with water if you are worried about residue.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 05-23-2010, 03:17 PM
I'm here to cause trouble
jimbauman's Avatar
Muriatic acid will definitely give you that "world war 1 trench experience."
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 05-23-2010, 04:27 PM
Cream or paste type toilet bowel cleaner works great. Most have a mild acidic content that is easy to work with and will polish up decent.
Old 05-23-2010, 04:38 PM
