rboylan's Avatar
Porsche Crest 1979 930 Engine Harness Plug Wire Identification Needed !!
Boys,
The voltage Regulator issue is addressed.
The Fuel and Plumbing issues are addressed.
Now this:
The numb nut I bought the motor from dropped the motor without unplugging the engine harness plug from the CDI board. The result is a series of wires(MALE PLUGS) from the engine harness in no particular order. I have attached a picture of the blank plug. I've also numbered. If anyone can post the correct colored wires and which number they need to correspond to, that would be awesome. Please remember this ia view of the inside (top of the plug)Thanks again guys.
1969 911E Albert Blue 1970 911E Iris Blue
1970 911T Signal Orange 1972 911T Gold Metallic
1981 930 Arctic Blue 1981 930 BB Auto(on ship)
1987 930 Cassis Red Met 1996 993TT Black
2007 997TT Cobalt 2017 991 Turbo Cab
Old 12-15-2001, 05:13 PM
I would suggest that you get a factory wiring diagram for the motor and the car. Compare the two and change the pins. The turbo engine harness is somewhat different than the N/A car harness. That is what I did, and it worked out great.
Dean
Old 12-15-2001, 06:22 PM
from an 87 930 in the shop:
1 two yellow
2 green/black trace
3 green/yellow trace
4 yellow
5 green/white trace
6 blue
7 brown/white trace
8 red/white trace
9 green/red trace
10 gray/brown trace
11 brown/black trace
12 red/white trace
13 empty
14 big red
this should get you close. on my 87, #4 was white. sorry, no 79.
206 637 4071
Old 12-15-2001, 06:29 PM
