Jupiter 911
Engine mounts?
Just notice both my engine mounts on my 87 Targa are worn, cracked and brittle. I plan on ordering two new ones from our host. Should I go with the original or do you think the sport mounts are any better? Thanks Lenny
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
AutoBahned
better for what?
post any specific questions that your search on engine + mounts doesn't answer for you |
Jupiter 911
I guess some have stated better shifting/acceleration?
Schleprock
I don't think there's a noticeable difference from the seat of your pants, between the standard and the club sport/cabriolet mounts. Either will do you just fine for the street.
However there certainly is a reason for there being two different mount types. Cabrio likely needs the stiffer mounts to offset the roof loss = less structural stiffness. Club Sport has them to reduce driveline lash. Either type pales in comparison to solid metal mounts. Don't go there.........
Kevin L '86 Carrera "Larry" |
French Import
If your engine mounts are worn, cracked, and brittle, chances are your transmission mounts will be in the same condition.
I will be replaciing all 4 on my 86 cab...
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Jupiter 911
Thanks, I will go with sport oem they are almost the same price as orig. oem. And I guess I should check the trans mounts.
AutoBahned
well, there are 2 levels of Wevo mounts also
if you mix/match for the trans. and engine, then you have maybe 8 choices, not just 4 to consider stiffer mounts = less movement of the big heavy powertrain rel. to the body BUT stiffer mounts = more NVH I really encourage you to run a search & read the threads, then think carefully about what you want before spending money |
gduke2010
I have WEVO. Our host sells them. There was a shifting improvement and I belive it was money well spent.
Jupiter 911
Just read the tech notes on the Wevo semi solid mounts, sounds very tempting. I might have to spring for the extra cash and do it right!
Yes, I second the WEVO's. I have them on both of my cars and every car I do work on. I love the "Blue" Pillows. They are available thru Pelican or on the WEVO website directly.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
Somatic Negative Optimist
Spray some penetrating oil from underneath into the threads. They can be so rusted that the crossbar ends are twisted and broken off when trying to open the bolts. Anyway, use a floor jack to support the load from underneath and replace the mounts one by one with correct torque ~60 ft-lbs.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Torque specs, for sure.
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
just me
I went to solid mounts and they do give a bit more buzz and noise. I'm not a good enough driver to tell if they are better, but with all the mods combined that I have the car handles great and feels very predictable.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
I went with the WEVOs and had a big improvement in shifting with a slight increase in NVH.
Money well spent and one of the more "reasonable" improvements to the car!
1981 911 SC 7 & 9 Fuchs, monoballs, 22/27 t-bars, 19/22 swaybars, M&K dual in/ dual out |
AutoBahned
T-bone -- did you use black or blue Wevos?
