Tadpole's Avatar
Spring plate question?
Just having a debate with a friend. Neither one of us has had an adjustable spring plate apart. Just wondering if it is one tube that goes through the back plate or is the tube two pieces? One piece attached to each plate....outer and inner. Hope that makes sense. Thanks
Mike
'75 911S
'76 911S
Old 05-18-2010, 01:20 PM
grateful user
don gilbert's Avatar
No, it doesn't make sense. An adjustable plate has 2 flat pieces kind of sandwiched together that pivots on a eccentric. Does that make sense? I'll see if i can find a pic
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 05-18-2010, 02:09 PM
burgermeister's Avatar
1 tube with a short plate welded to it. The other plate is long and has a hole in it, which just fits over the tube. 2 bolts, one with eccentric, connect the long plate to the short plate. The other end of the long plate bolts to the banana arm.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 05-18-2010, 02:16 PM
grateful user
The big nut on the rear is the adjustment nut. See how the two piece move to raise or lower?
Old 05-18-2010, 02:18 PM
Tadpole's Avatar
Thanks guys
Mike
'75 911S
'76 911S
Old 05-18-2010, 02:23 PM
Somatic Negative Optimist
Gunter's Avatar
In the picture, the eccentric sits at the lowest point meaning: the car can only be raised but not lowered further.
I suggest you get the Bentley Repair Manual which has good pictures and explanation how things work, especially the indexing of the T-bars.
It is more involved than you think.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-19-2010, 08:07 AM
