-   -   How do you do a compression/leakdown on 911? (http://forums.pelicanparts.com/porsche-911-technical-forum/543276-how-do-you-do-compression-leakdown-911-a.html)
axl911 05-19-2010 11:08 AM
How do you do a compression & leakdown on a 911/930 since the spark plug is on the top side of the engine?
On a 964/993, it's easy to do it using the bottom plugs.
But on a 911/930, is it possible to use the flexible hose that normally come with the testers to screw into the sparkplugs hole?
thanks,
anthony
Steve@Rennsport 05-19-2010 11:43 AM
Hi Anthony,
While its not easy on some cars such as a 930, one uses the flex hose and install this into the plug hole. I usually do thing by feel since its tough to see anything,.....:) :)
Jakkalas 09-06-2011 01:26 PM
I have been told that in order to do a leakdown test, the engine has to be removed. Is this true? Or can a compression and leakdown test be done without removing the engine on a seventies or eighties 911?
RSTarga 09-06-2011 01:30 PM
I was under the impression that the leakdown should be done on a warm engine, so it would be almost worthless on an engine out of the car. A leakdown is to see where the leaks are, if it's rings the tolerances are wrong on a cold engine.
LJ851 09-06-2011 01:40 PM
You can do both tests in the car, it is not difficult. While a warm leakdown may be more accurate, a room temp leakdown on a removed engine is much better than nothing. Any substantial leakage will leak hot or cold.
