got a new bosch cdi, now which coil?
Hi, everybody. i got a new bosch cdi for my car, i am very happy with it. Now, for the coil, which one should i get????
the bosch silver one, or, i have the posibility to go to a coil maker and make a custom one with the right spec, which one you recommend???? thanks!!
911 T 2.4 (MFI) 1973 with 911 E fuel pump from 1971 The beatiful Buenos Aires, Argentina! |
the silver ones tend to be crap. i had a new die in 10 minutes. try to find an original black bosch coil with the warning lightning bolt on it.
so if they are crap, i think i'll get a custom one built with the same spec, what do you think??
Max Sluiter
Can you take him the old black one (even non-operating)?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
I have had a Nology ProFire PFC-M75 coil [pn# 151 991 750] for CD Ignitions on my 73 2.7 with Bocsh CD. It has worked very well for 10 years and I really trust it. I am not sure if our hosts carry it, but you can buy from Nology or others on line. This model is designed specifically for CD. It is a transformer type with no oil and can design.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
got the idea i think, i'll go and get a custom made 45.000volt transformer, with the same spec like the bosch black, with NO oil on it, and then i'll try what happens
How would ANYONE have the knowledge to custom make a CDI ignition coil/transformer...?
It's not a magnetic field "storage" device as in an ordinary, ancient, ignition coil but a reasonably low inductance high frequency coupling step up transformer with QUICK rising edge coupling capability. Good luck with that one. |
