Leak Down Test
Performed a leak down test on a 3.2
The results are:
cyl 1=40% cyl 2=2% cyl 3=2% cyl 4=30% cyl 5=1% y cyl 6= 3%
Does this engine need to be rebuilt or what should I do to find what is wrong with it.
Old 11-01-2013, 09:28 PM
Platinum Member
dad911's Avatar
You can should get more info from a leakdown test. testing cyl #1 & #4, you should be able to hear where the air is escaping. Intake or exhaust would indicate the respective valve is leaking, if the air is leaking out the vent then it is leaking past the rings.
Has the car been sitting? If so, drive it & test again.
Old 11-02-2013, 04:53 AM
wolds's Avatar
Did you confirm that the valves were in adjustment before you ran the test? If you did start listening for air leaking past the valves. Also try a small amount of oil in the suspect cylinders (1&4) and see if that improves your numbers. Could be as simple as too tight on your valve lash. Warren
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Mo money = mo parts
Good advice here. Valve adjustment, drive car and repeat test. Also, I would do a compression test. 30 and 40% leak down numbers will likely be confirmed with lower compression.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 11-02-2013, 05:01 AM
Thanks for the comments.
The engine is out of the car, we tested it before installing it. No work was done to the engine, the transmision had a problem.
The air is leaking from the vent, like dad911 said I suspect the leak is from the rings.
Now, is there another test I can do to make sure what is wrong with the rings ?
The engine has been out of the car for almost 20 months.
Old 11-02-2013, 04:35 PM
With the engine sitting around for 20 months, stone cold, your leak down test is not that valid. The good numbers are good, and the bad numbers 40% are not reliable. You want to test it hot, with the cylinders wet.
I would say forget about it, drive it, and re-test.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-02-2013, 05:03 PM
