Transmission mount torque specs
Anyone know where to find the bolt torque specs for the transmission mount bolts?
There is one 19mm bolts on each end of mount and then four 13mm bolts in the center. Also, my "flat" washers on 19mm bolts are pretty bent up. Should they be replaced? Thanks, Hank |
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 05-20-2010 at 10:53 AM.. |
The trick is leaving the 13mm bolts loose while you start threading the big one. Tighten them all up once started by hand. IIRC, the torque spec is 60 ft-lbs on the big one. But that's just from memory.
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
Yes, wrench size...
Yes, I did post wrench size. (I am pretty new to this)
![]() I did tighten all the bolts by hand first. Then put a little torque on each bolt. The washers are no longer convex. Transmission support seems to be snug against body, but the washers are not flush against support. They seem bent in different directions. Will post pictures as soon as possible. Thanks for the replies gentlemen, I appreciate the help. These forums are great. |
