Oil Leak from Head Gasket?
Is the above possible? I've been told by a mechanic that my oil drip is likely due to a head gasket leak. This doesn't make sense to me given that there are no oil galleys running through the head and cylinder as on a non-air cooled engine.
THANKS! |
what year and model?
You could be leaking oil between the head and cylinder if you have a broken stud, but it would also be leaking down the side of you engine case.
So the motor is standard early 911. It's built on a '75 930 case, but is normally aspirated.
Head stud... yikes. The leak seems to be coming from the head area and not the case:cylinder interface. I'll keep my fingers crossed on the head stud. Would you expect compression or leak-down issues if the stud were the problem? |
how bout some photos?
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
The car is at the shop right now. I'll try to get under it and snap some pics over the weekend.
Thanks for the help! |
Yup, it would be head studs.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Is there anything else I can do short pulling the engine out that might indicate it's a head stud problem
You should be able to check the head studs by simply removing the valve covers. And then checking for broken ones.
Good luck. Jay
2002 Boxster Speed Yellow |
