964 with fuchs?
Anyone have pics of a widebody 964 with fuchs? I've seen them on a narrow body but not a turbo body. Also do you have any recs on where to buy some nice aftermarkets? Many thanks.
Old 05-21-2010, 09:35 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
i doubt you have seen OEM Fuchs on a 964. i have seen one 964 on this board a while back that had some off the wall made replicas on it, that quite frankly just dont look right. however, in theory, if you had a narrow body 964, in which you made into a widebody, you could probably get the rears to fit with spacers, not so sure about the fronts though..
as far as aftermarket, look at CCWs..
Old 05-21-2010, 10:50 AM
80-911SC's Avatar
i have seen a few that were originally sc's that have 964 kits that didn't look bad .....
Old 05-22-2010, 11:49 AM
Fastracer73's Avatar
Backdated 964 with "Fuchs'alike"
Paul Stephens Autoart:
PS Autoart | Practical Classics | Bespoke Porsche built to your specification
Very nice backdated 964's
Fuchs - o - maniac
-78 911 SC
-65 912 (911 R project)
Old 05-22-2010, 12:04 PM
Fuchs will not fit on a 964, the offset is wrong for the body and wheel.
The tire would stick an inch or two OUTSIDE the body.
To put a 964 wheel on an SC, you need a 1" spacer on the front and a 2" on the rear, roughly.
There are probably Fuchs 'copies' with an offset that would work, though.
Old 05-22-2010, 01:28 PM
Here, I Photoshopped a '94 3.6l Turbo with Fuches.
-Eric
Old 05-23-2010, 06:41 AM
ERH ERH is offline
An old thread:
fuchs on a 964
Old 05-23-2010, 05:32 PM
Todd Simpson's Avatar
Here you go.
New Project 91 C2 RSR
Call Lindsey for the fuchs.
Old 05-23-2010, 06:06 PM
Is not that about the same a
amount we add on spacers when we add turbo fenders to a 911 and we put stock Fuchs on?
If so, seems with turbo fenders on a C2 we could run Fuchs w/o spacers.
Old 05-23-2010, 06:11 PM
