Desi Porsche
Send a message via MSN to rswamy
Help 84 Carrera - Evap box removal a B&^%h
I removed the two brackets holding the box and two plumbing lines coming into the evap. The box moves but it seems like something is holding it in the bottom. I'm wondering if it is the drain hose or vent to the cabin. Let me know how I can get this out. Thanks a bunch.
1984 911 Carrera, Red
Old 05-23-2010, 02:32 PM
I remember having to remove the passenger carpet in the cabin. There was a small plywoodish board held by a few screws. Once that's removed, you should be able to see what needs to be removed in order to get the evap box out.
Don't give up. Be patient and don't force anything. You'll get it!
Old 05-23-2010, 02:39 PM
Desi Porsche
Thanks, KeoRS. I'll give it a shot.
Old 05-23-2010, 02:42 PM
No problem.
I hope it helped. Let us all know how it went!
Old 05-23-2010, 03:04 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
The small board is the floor-board in our '86 and is held down by one 10mm nut.
Did you remove the two clamps holding the vent, and the bowtie?
I think the drain hose may be the issue.
If it is, push the tube up from underneath the car, and pull the evap enclosure strait up.
And, why are you removing the evaporator box?
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-23-2010, 03:17 PM
brads911sc's Avatar
You need to remove the thermostat in the pass floor area behind the floor board. This slides into the Evap so there is a tight seal. However it also acts to hold the evap box in the hole. Once you remove this, it should slide right out...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 05-23-2010, 03:40 PM
Brad,
You are right!
I missed that.
Gerry
1986 911 Targa.
Only in L.A.:
Old 05-23-2010, 03:51 PM
Desi Porsche
Got it guys. That was it. The resistor box for fan speed control. Reason for removal, I was recharging the system with ES12, low side pressure was too high and wouldn't take more than 8 oz after overnight vaccum. I figured expansion valve was clogged. Low side was around 80 and high side was around 160psi. Any more charge was increasing low side and vent temp wouldn't go below 75. I was afraid I would twist the copper tube holding the exp valve so I took the evap out. Looks like I'm going to bite the bullet and do some upgrades. Let me know your thoughts.
Old 05-23-2010, 04:07 PM
brads911sc's Avatar
Great.
That is a very slippery slope... lots of posts on this... On the other hand was driving my black targa around houston today with 92 degree ambients and i wasnt sweating!
Old 05-23-2010, 05:56 PM
Desi Porsche
Great.
Thanks, Brads911sc. I read about it a little bit. If you did, let me know your experience. I was thinking renair procooler and evaporator. I think my nippon denso compressor is good. What are your thoughts, or should I go for the whole shabang? Looks like a $1400dent.
Old 05-23-2010, 06:01 PM
Check my A/C post of 5/15/2010.
Gerry
1986 911 Targa.
Only in L.A.:
Old 05-23-2010, 07:26 PM
