Unhappy motor in no tach
Got my new motor in. Now the tach does not work? any help?...Matt
Old 12-15-2001, 07:58 PM
What motor did you put in? A 2.0-2.4 tach won't work with a later motor, some 2.7 tachs work with 3.0s and 3.2s and 3.6s have their own tachs.
If its the same motor find the black wire with purple stripes and check continuity on the wire through to the tach. There is also a ground on the tach.
If its not the same motor get the right tach and then make sure the black and purple wire goes straight through
Old 12-16-2001, 04:38 PM
black wire with purple stripe goes on the distributor with other wire. Same motor and tach from car just made motor bigger. But the tach doesnt work after motor went back in. Any suggestions
Old 12-16-2001, 05:00 PM
Early_S_Man's Avatar
Porsche Crest
Matt,
Clean the forward 14-pin connector from the relay/fusr/CDI panel to the body wiring harness.
The pins are silver-plated, so use isopropyl alcohol and a bristle brush such as an old toothbrush. After testing, you may have to do repeated cleaning to get it working. Pipe cleaners and the alcohol work well on the receptacle (female connector) but it is very hard to see if there is a corrosion problem down in those sockets!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-16-2001, 05:06 PM
