Wheel spacer questions
All, I have a few quick (and hopefully not naive) questions about wheel spacers.
I get that they will widen the track of the car, but what are the down sides? Will I need to get my car realigned if I put them on the back only (I have a 1984 3.2 with 6&7 x 16 Fuchs)? Are there brands that members agree are best? What width spacer makes the most sense if I intend to keep my 6s & 7s (vs changing to wider wheels)? Thanks!
1984 3.2 targa |
Ruby911
- Depending on what width you need, they can add a lot of unsprung weight. I used to thave 32mm spacers on my '84 carrera that weighed 4lbs each.
- Some say they add stress to wheel bearings. - H&R makes a high quality, hub-centric product and can you pick used ones here fairly often
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
Senior Advisor
I have the Porsche turbo ones on the rear now. 21mm and they fill up the wheel wells nicely. You will have to replace the studs with 68 or 72mm ones. If you don't want to go that route, there are some (H&R) that bolt to the existing studs and have another set of studs on them for the wheels. In any case make sure there the "hubcentric" type. Porsche factory ones weigh about 1 lb each.
08 Cayenne Turbo |
i have h&r 23mm spacers on the rear and have had no ill effects. i love the look of them as well.
no spacers ![]() spacer
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
nineball,
Are those spacers with longer studs or are they adapters? I'd like to get them as well but I didn't see them on H&R's website Does anybody make aluminum spacers?
Kurt |
adapters, meaning you have to bolt these on to the existing studs and they have their own studs. they look like this:
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. Last edited by nineball; 05-26-2010 at 01:33 PM.. |
Hmm, I only saw the spacers, do they have a part number..? I guess I didn't see the 23mm adapters.
Kurt Last edited by KNS; 05-26-2010 at 01:35 PM.. |
sorry i do not. i bought a pair of adapters from another pelican a while back that were advertised as 21mm. when i got them they were 2.5" wide and useless to me so i traded them locally to another pca member for the ones on my car now.
