Obsessed
Brake gurus identification help please
Can someone that knows much more than me confirm what calipers I have on the front of my '75 911? I thought they were "M"s and the rebuild kit I ordered as such certainly seems to fit right but a brake pad order has thrown what I think I know into question.
There seems to be 3.75-4" between mounting bolts, I don't think they are Aluminum but? A conversation w/ Pelican regarding my order today makes me think that the front and rear calipers for my car should be the same size, they definately are not. ![]() ![]() Thanks, Travis
'73 Mercedes 450 SL '75 911 Targa (long gone, sniff..) http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog "Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!" |
If the mounts are 3.5" OC then they are either A or wide A, both use the same pads.
M mounts are 3" OC
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 05-28-2010 at 03:37 PM.. |
Obsessed
Was A the early '75 and would they use the same rebuild kits as M?
note that there was a typo in my 1st response, the mounts for A and S and wide A are 3.5", these all have the pads w/ the same planform, but the S pads are thicker
