Carerra Fuel Lines...Again!
I just bought a 1988 three owner southern 911 cabriolet with 130,000 miles. The service records go back 12 years. I knew there were problems with the OEM engine fuel lines early on....but assumed that when the OEM problem was discovered the replacements were fixed (properly manufactured going forward)..... After sorting through the service receipts I noted that the 93011059505 lines were replaced in 11/02....2/06....and most recently in 10/09 and all of this work was done by the same shop. Replacing these lines three times in eight years does not seem right to me. Any ideas?????
Old 06-01-2010, 06:37 PM
brads911sc's Avatar
maybe it was just an opportunistic mechanic... I took my 1 year old honda into the dealer for an oil change and tire rotation, and they tried to sell me brake caliper lubrication... it had 12k miles on it... I hit the roof but pretty sure alot of people fall for these things.. so having a mechanic replace a fuel line that is a known problem area every 3-4 years isnt that outragous on the spectrum of outragous auto mechanic behaviors... Id assume it didnt need to be done that often...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 06-01-2010, 07:11 PM
You might be better off having the fuel lines made. Every two years seems a bit extreme. Not exactly a cheap line to replace either.
Karsten
1977 Turbo Carrera - Work in progress
1971 911E Targa - Almost gone
Old 06-01-2010, 07:17 PM
