16s & 17s?
I was having my 6 x 16 Fuchs re-worked into 9 x16 for the rear of my '78 SC. Problem is there are only a few tires available for these wheel sizes. I am contemplating going to a 9 x 17 in the rear and run a 245-40-17 and run 225-50-16 in the front. The diameter of the two are almost identical.
Anyone see a problem? Thanks for the help! Lindy |
There are no issues with running 16s on the front and 17s on the rear. The diameters of the tires don't even have to be close. I have 245/45-16s on the front and 275/40-17s on the rear of my car...
If you go with a 9x17 in the rear, I would use a 255/40-17 tire, though.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Thanks for the help. I'm having my wheels done by Trudesign in Denver. Looking forward to the end results!
Lindy |
Schleprock
Agreed. 16x9 is a poor choice if you're having Jim make you 9's. The 17 in. selection is SO much better these days!
Kevin L '86 Carrera "Larry" |
Thanks Kevin, you're right about the tire selection. 225-50-16 is about all you can get anymore in a street tire. I was a little nervous about the different sizes, 16's front and 17's rear, looking funny but now I think they will be fine. I really like the dish of the 9's, I've always liked a big lip.
Thanks again. Lindy |
MBruns for President
Why don't you have Jim make you a set of 7.5 x 17 fronts out of another pair of 6's??
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
The set up front used to be in the rear and are 16 x 7. The stock sizes in '78 were 16 x 6 in the front and 16 x 7 in the rear. I'm going to see how they look when Jim is done with the new 17 x 9 in the rear and the 16 x 7 in the front. If it looks goofy I'll send the 7's to Jim and have them made into 17's as well.
Lindy |
While acknowledging there are much fewer choices and in the 17" size, the demise of 245-45x16 tires is slightly exaggerated. While Tire Rack doesn't stock them, other companies do. Here's a lineup from Tire-Easy.com (no affiliation).
Nexen N 3000 245/45 ZR16 94W BSW only $78.60 Fulda Carat Extremo 245/45 R16 94Y Rim protection only $55.40 Fuzion ZRi 245/45 R16 94W BSW only $108.40 Yokohama AVS ES 100 245/45 ZR16 94W BSW only $130.60 Kumho, Hankook, Continental, BF Goodrich and Toyo also make tires in this size. Type "245-45-16 tire" in a google search. Sherwood |
