911 tweaks's Avatar
front strut ~shock question
I am in the process of lowering a 76' 912 and needed to remove the original metal spacers to allow further lowering range of the front...anyway, when I removed the nut in the front trunk that holds the top of the strut/shock, the piston proceeded to go down and into the strut/shock...
huuuuuummmmmmmmmmmmm I said to myself...so I pulled the shaft back out and let go and back in it went...there is some resistance if I push & pull on the shaft, HOWEVER, this means these are toast as this shaft should always want to come up, even if it creaps up when you let go of it right...??
Thx, Bob
I live for 911 tweaks...
Old 06-06-2010, 10:41 AM
Zeke's Avatar
Boge and Konis do just that. It's normal.
Old 06-06-2010, 11:12 AM
PRO Motorsports
Tyson Schmidt's Avatar
What Milt said. Not all shocks were gas charged. The standard Koni's and the standard Boges were hydraulic.
The Bilsteins, the Boge Turgo-Gas and the Koni Sports are all gas pressurized.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-06-2010, 11:22 AM
911 tweaks's Avatar
thx guys for the replies...
I investigated further...the struts are boge...as far as the inserts go, I did not check...
funny thing is that the passenger side when I removed the washer, the piston stayed where ever I positioned it...my guess is these are original to the car...1976 912E...
If I replace the fronts w/ Bilstein sports, should I replace the rear shocks as well...they too look original or very old but they have a 1/4" wide decal anound the bottom of the shock and look to originally have been a lt blue color...
My next question is how do I lower the rear of this car...I will post pics here & if you suggest, I will post a seperate thread as these rear torsion plates do not have the 2 bolts at the front of the plate near the torsion tube which are the ones to change ride height...
Thx for any and all input here...
Bob
Old 06-06-2010, 01:14 PM
911 tweaks's Avatar
here is what I am working with...how do I adjust/lower this rear suspension...?? re index the torsion bars...??
Thx, Bob
Old 06-06-2010, 01:27 PM
Under the radar
Trackrash's Avatar
Yep, re-index the torsions. A couple of other threads on this. Do a search.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-06-2010, 01:32 PM
Looks like you have some rebuilding work to do on your suspension. That surface rust might mean more damage inside torsion tube. I'd rebuild calipers too.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-06-2010, 01:46 PM
911 tweaks's Avatar
thx guys...I'll do a search...
Milt & Tyson...how then do I determine if the boge ( I removed one front shock & it was black colored) if they are still functioning or are toast...??
Thx,
Bob
Old 06-06-2010, 04:24 PM
My standard red KONI adjustables have this stamped on the housing.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 06-06-2010, 05:12 PM
911 tweaks's Avatar
did not see any of that on the front shocks...maybe I need to completly remove them to see any possible such markings...??
Old 06-06-2010, 05:28 PM
