Which shifter is better Wevo/Rennshift
I want to purchase a shifter. Can anyone provide feedback on what they've found good and bad between the two products our host sells, Wevo/Rennshift? Would you prefer the extended shifter that Rennshift sells?
With the Wevo you have to reuse your current shift housing
Rennshift is a complete unit Great feedback all over this board about both of them, I have the Rennshift and like it very much. |
There all better.
They're all better
I'm an ass for not searching? Please disregard question.
No, your an ass for not buying!!:) And if you couple it with a Wevo or other coupler, you have the best you can get. And change the bushings.
I just did the same search before rebuilding that 915-one thing I didn't find on the boards was that Rennshift also sells a package that include the shifter and the shift coupler together for $660. Worth considering when you're redoing the whole shifting system.
Once properly adjusted you should see a marked improvement in shifting!
Yes, just a minor parts issue. the shifter works flawlessly.
I purchased the Rennshift, then within a week of installing it purchased their coupler. I don't think you should do one without the other in my experience. The shifter tightens up the tolerances, which exaggerates the looseness of the coupler. The two together shift almost as good as my newer Audi. Well worth the money. Your going to feel like you just put a whole new transmission in your car! Tech support from JWest was great too.
Well I would have said buy the Hargett. My '72 915 updated with the omega spring and the Hargett shifter is easier to deal with than my Ruf 3600S. And Mark is a great guy. But if you already bought one of the others, it'll be better than what you had.
or something |
I'm literally moments away from ordering a Rennshift and saw the coupler comment. I already have new bushings ready to replace when I do the install, is it a waste to redo the bushings over installing the rennshift coupler?
no they all have to be top notch condition
or did you mean the bushings INSIDE the coupler?? if so then a waste if you are going to repl. coupler |
how about the hargett with it's linkage? only a little bit more money than the other two?
The Hargatt shifter is more for racing but wow, that would look great! And I think it's hard to keep the parking brake. or the back seats.
http://forums.pelicanparts.com/uploa...1275958638.jpg Or you can make a stand for a rennshifter. |
why the back seats?
I have a wevo and its light years ahead of the oe shifter, very happy with it, Kevin
| All times are GMT -8. The time now is 07:11 AM. |
