Which shifter is better Wevo/Rennshift
I want to purchase a shifter. Can anyone provide feedback on what they've found good and bad between the two products our host sells, Wevo/Rennshift? Would you prefer the extended shifter that Rennshift sells?
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
With the Wevo you have to reuse your current shift housing
Rennshift is a complete unit Great feedback all over this board about both of them, I have the Rennshift and like it very much.
-Vinny 1983 911SC |
Senior Advisor
There all better.
08 Cayenne Turbo |
They're all better
I'm an ass for not searching? Please disregard question.
Senior Advisor
No, your an ass for not buying!!
And if you couple it with a Wevo or other coupler, you have the best you can get. And change the bushings.
08 Cayenne Turbo |
I just did the same search before rebuilding that 915-one thing I didn't find on the boards was that Rennshift also sells a package that include the shifter and the shift coupler together for $660. Worth considering when you're redoing the whole shifting system.
Purchased 5 Min. ago!
Senior Advisor
Once properly adjusted you should see a marked improvement in shifting!
08 Cayenne Turbo |
After searching I noticed you had a parts issue with your purchase of the Rennshift. I hope that doesn't happen to me.
Senior Advisor
Yes, just a minor parts issue. the shifter works flawlessly.
08 Cayenne Turbo |
Go Speedracer, go!
I purchased the Rennshift, then within a week of installing it purchased their coupler. I don't think you should do one without the other in my experience. The shifter tightens up the tolerances, which exaggerates the looseness of the coupler. The two together shift almost as good as my newer Audi. Well worth the money. Your going to feel like you just put a whole new transmission in your car! Tech support from JWest was great too.
1981 SC ROW Coupe |
Well I would have said buy the Hargett. My '72 915 updated with the omega spring and the Hargett shifter is easier to deal with than my Ruf 3600S. And Mark is a great guy. But if you already bought one of the others, it'll be better than what you had.
Original owner 1986 944 1987 951 968 wing from CPR, Deutsche Nine headlights, KW Variant 3s, Lindsey Stage 2 intercooler, Big Reds 2003 Ruf 3600S S-Car-Go equal length headers, otherwise almost stock 72 911T w/ SC 3.3SS engine MoTeC Hargett ITBs |
AutoBahned
I'm literally moments away from ordering a Rennshift and saw the coupler comment. I already have new bushings ready to replace when I do the install, is it a waste to redo the bushings over installing the rennshift coupler?
1983 SC - sold 2002 996 C4S - sold 1968 912 |
AutoBahned
no they all have to be top notch condition
or did you mean the bushings INSIDE the coupler?? if so then a waste if you are going to repl. coupler |
just me
how about the hargett with it's linkage? only a little bit more money than the other two?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Senior Advisor
The Hargatt shifter is more for racing but wow, that would look great! And I think it's hard to keep the parking brake. or the back seats.
![]() Or you can make a stand for a rennshifter.
08 Cayenne Turbo Last edited by James Brown; 06-07-2010 at 06:00 PM.. |
just me
why the back seats?
I have a wevo and its light years ahead of the oe shifter, very happy with it, Kevin
