Why do I have one hot exhaust port?
![]() Doing a exchanger update I found one hot port. Anybody want to take a guess? My list of ideas (not in any order): Bad injector Bad injector line Bad valve seating (need to do a leakdown) Leak at exhaust flange REALLY bad intake leak on the runnner. Bad fuel distributer Bad karma from pissing off my last girlfriend Car runs and drives well.. idles well..
JP '76 911s Ice Green Metallic bone stock |
I'd guess that you have a bad injector. Dribbling fuel, volume is down = lean cylinder.
Mt thought is poorly buned fuel equals black soot.. not to mention backfires. but a clogged injector could do it.. still good partial spray.
Make My Day
Running lean on that cylinder by the looks, how does the plug look compared to the others?
74 911S Targa ROW Building Designer/Business Owner |
just me
what's all the black gunk? is that from oil?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Well its not Porsche turds!
Replaced valve cover gaskets at the same time.. hopefully that slows things down anyway.
Senior Advisor
That might be the one good burning cylinder compared to the others.
08 Cayenne Turbo |
The car runs well.. doubtful?
my first thought also. worn guides, oil use, still runs pretty good. just not using as much oil in that hole.
GAFB
Are the injectors sealing? Lots of old CIS cars out there bleeding air past the injectors.
Several BMWs |
Gonna have to use a infrared thermometer from here on... she's back together.. but definitely need to fix that cylinder.. Im thinking I'll pull all injectors and bring em to my bosch service center.. get am matched.. and also have them tell me what that injector looked like compared to the rest too.
I need to check it.. once my neck stops aching from doing the HE backdate I will.. ouch.
Senior Advisor
Oh, while your in there, looks like a good time to change the oil return tubes out. That looks like a source of some oil leaks. BTW, did you break any exhaust studs?
08 Cayenne Turbo |
Not one.. heated em up and spun em off. Ok some luck was involved.
Burn the fire.
Check the injector on that cylinder. See how it's spraying at opening pressure and high pressure.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
What was the problem with that one cylinder? When changing to SSI's I had one that looked like that (different from the other 5). I'm concidering replacing the injector and o-ring on that cylinder.
'82 911 SC |
Pull the plug and look at it. If it is really white, with maybe little flecks. switch out the injector. If it is a little sooty or brown deposits, probably OK. If you pull a few plugs, they should be fairly consistent.
