-   -   3.2 intake on my EFI 2.7? (http://forums.pelicanparts.com/porsche-911-technical-forum/546942-3-2-intake-my-efi-2-7-a.html)
zook 06-08-2010 09:58 AM
Hey:
Will the 3.2 intake bolt up to a 2.7?
Thank you.
pat
jpnovak 06-08-2010 10:03 AM
Physically, yes it will fit with no issues. functionally, the ID is a bit large for the 2.7 and you will need to blend the head intake diameter to match the nominal 40mm intake runner.
KobaltBlau 06-08-2010 12:10 PM
I had the same question recently about a 3.0. I had some (maybe faulty) memory that there was an incompatibility with the 3.0 heads but I guess it's a straight bolt up also?
Scott R 06-08-2010 12:48 PM
Guy posted some pics a few days ago, you need to machine in the indent for the injector and mate up the intake runners to the earlier heads. He said he used some sealer between them.
KobaltBlau 06-08-2010 01:04 PM
Scott, are you referring to 2.7 or 3.0 or both? Could you possibly post a link to the thread - I can't find it :(
I want to know if it's possible to put a 3.2 intake on a big port 3.0 without machining the heads. The ports are only off by 1mm so I'm not really worried about that issue.
jpnovak 06-08-2010 01:18 PM
You need to clearance the CIS injector port. The EFI tip in the 3.2 manifold is in a slightly different position compared to the CIS runner. I am sure much has to do with the diameter of the injector bodies. There are some pictures here.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/499101-efi-conversion.html
Keep in mind these are for a 930 head where the port diameter is quite small. If you look at page 2 of the thread (post #50) you will see a spacer that can prevent modifications to the head from being made. It would be easy to fab the spacer from phenolic or ABS and install longer studs to compensate for the distance change.
SO yeah, it can be done without grinding the heads. Slight, yet reversible head modifications are required.
Scott R 06-08-2010 01:28 PM
Machine some spacers, sell them and make a fortune? :)
KobaltBlau 06-08-2010 03:56 PM
Nice, post #50 is just what I wanted to see. I wonder if there's any chance the injectors would just fit though, with the 3.0 big ports.
When you say "slight, yet reversible head modifications are required" you mean bolting on the spacers? does that count as modifying the head?
In any case, if I have to use spacers I should be able to make some very much like the ones in post #50 with some phenolic or ABS, but it should be easier because the port size is almost the same. Make a fortune? I don't think so! Now, where did I put that CNC?
JmuRiz 10-14-2010 10:17 AM
And/or make some that taper from the 3.2 intake manifold to the small intake ports on the 2.7.
Anyone have a solution for the port size difference between the two. (FYI I'm working with a 1977 2.7)
