Is the lift at all unstable, some of the one I've seen online are much wider and actually lift between the tires at the outer edge of the car. Thanks for the info........KC |
Not at all...
Its rate for 6,000 pound, so my 2000 lb is not even a work out. It can raise to 56". I had it up to the max I could do in my garage. Actually if you look close you will see that my garage door opener is actually in the car. When I had it up to my max (plenty of room to drop the engine) I give it a good shake from all 4 corners and had no hesitation to go under to start cleaning (took me about an hour to do the driver side heat exchanger). Of course it has safety stop every 8" (I think), you raise the car above where you want, than release the hydraulic until the stop engage. For the P cars and other rear end engine, you put the cylinder up-front so you got plenty of room to work in the back. KC: I think you are hook, PM me I'll give you my number:D:D:D http://forums.pelicanparts.com/uploa...1276128890.jpg http://forums.pelicanparts.com/uploa...1276129055.jpg |
http://forums.pelicanparts.com/uploa...1271112234.jpg[/ |
Hi JJ 911, nice lift. Glad to find one made in Canada, it is on my wish list but was not about to buy the "made in china" version. I didn't come across these guys when i was searching.....so thanks for the tip.
What did you use on your HE's to get them that clean? Next little project for me while mine is still on jacks. I'll be in Ottawa next week for a couple lapping days at Calabogie. My Brother ( fellow 911 owner, and Ottawa resident) were possibly taking in a PCA cruise next Saturday Morning June 19th. Do you attend any of their events? |
I must say, I've some issues that may or may not be related to jacking under the engine (also why I don't really feel ok doing it).
The last time I did it, the engine sounded all funky and didn't start right away. It also made only 4 or 500 rpm and then shut down. Had to start the car 3 times before it ran normally. I never ever had or have any problems starting the engine, only after jacking it up that way... |
Should be available in Newfieland...
PM me the details of your visit (including your brother name, I may already come across him) and I'll try to meet you guys, I'm leaving for Niagara on Thursday so I'll miss the coffee run on Saturday. Cheers J.J. http://forums.pelicanparts.com/uploa...1276160237.jpg |
I stuck 2x4s under the body jack points and lifted that way. Rear t-bars for the rear. About 3-4" at a time. There it remains, undergoing (slow) restoration, about 14" of total lift right now, which is plenty for me to do what I need.
So it looks like the only damage shown thus far was as a result of a car falling onto a jackstand.
We will be waiting forever to see a jack-damaged engine. |
You know, you can do what you want with your car. Frankly, I do not care.
That said, I have intellectual heartburn over using the single most expensive component of my car as a lift point when there are alternatives availble. Grady Clay (whose advice you should ignore only at your own risk) offers the following: Quote:
Here's a couple of pictures as requested. I made it so it can be adjustable but for now it is just used on the 911. The center tube is 28 inches long. 2 X2 square tubing 3/16ths of an inch thick wall. The extension pieces are 1 1/2 X 1 1/2 square tubing 3/16ths inches thick. the overall length is 41 3/8ths inches. I use a 7000 lbs. jack. Nothing fancy, but it works.
http://forums.pelicanparts.com/uploa...1276183272.jpg http://forums.pelicanparts.com/uploa...1276183303.jpg |
Mike what part of the swing arm to you lift against. I'm having a hard time picturing that. Is it the swing arms or the trailing arms?
I like the idea though. |
I use a simple 4x4 with one jack right in front where the tranny shaft enters the body using the Porsche structure point.
Hey Todd, sorry for the confusion. It is actually the trailing arms that I am using. I am calling the trailing arms swing arms.
Not sure what year your car is, tim. On my '71 911 I just put the floor jack under the rear engine MOUNT and jack until the rear wheels are off the ground. I can then place the jack stands under the torsions. Takes about 30 seconds.
I've seen experienced Porsche mechanics routinely jack up 911s by the engine. :eek: Keep in mind that up until '77 911 motors were made of MAGNESIUM. I would never jack up my CAR using the motor. |
My car is a '82.
What exactly is the rear engine mount ? I know the 2 mounts in the back, but I'm guessing that's not exactly what you mean because I cannot see myself putting a jack there ;) |
http://forums.pelicanparts.com/uploa...1276293790.jpg
Even with this small jack I'm not jacking on the motor and the rear wheels are off the ground. http://forums.pelicanparts.com/uploa...1276293862.jpg |
That looks like a great spot!
I'll try that next time. |
| All times are GMT -8. The time now is 01:28 AM. |
