LinkBack | Thread Tools | Rate Thread |
Decode it.
Let me help you avoid being an idiot - by showing you how I am one
I picked my bumper up at the paint shop today. It is perfect.
All I wanted to do tonight was to put it on so I could drive my precious Porsche tomorrow. So I dig in and start putting everything back together. I hadn't reattached the AC condensor etc... so I took care of that first. Then the valance and the new smile. I was ready for the bumper. I attached the chunk of aluminum that goes on the right side. Then grabbed the lights. Idiot move #1 - Can't put the lights on with the aluminum plate in place. Off it came. Install outer set of lights. Re-install aluminum plate. Hold bumper up to car and realize the inner lights can't go on with that damn plate in the way either. So off it comes again. Now I can attach the inner lights. I hoist the bumper up to align it with he bolts and notice that I forgot to install the headlight washer tubing & nozzles. Sheesh. Guess what? My Oeketer clamp tool won't fit the clamp WITH THE LIGHTS installed. So I have to remove the inner lights and that damn aluminium plate again. Lights back in, plate back on. Ready? Yes. I maneuver the bumper in to place. Looks good. Bolts on, smile lines up nicely. I'm happy. Until I realize I didn't attach the right side bolt for the valance. Guess what's in the way? The aluminum plate (not a problem on the left side of the car). So off comes the bumper AGAIN. Although this time just partially...just far enough to reach that bolt and install it. Now I'm feeling good. Bumper bolts back in. I dink with the rubber strip and can't figure out how to get it to slide on without the little clippy things rotating and popping off. I give up after awhile figuring I'd post here for a technique and move on to my bellows. I test fit the bellow and sheetmetal on the left side and it looks good. Then to the right... Guess what? I forgot that the right side bellow CAN"T BE INSTALLED AFTER THE BUMPER IS ON THE CAR. It has to be attached to the bumper BEFORE THE DAMN ALUMINUM PLATE! By this time I'm too frustrated and too tired. I, for the first time in the evening make a SMART move and decide to go to bed. If you remove your bumper to replace your smile or get it painted or whatever, remember to come back and re-read this post so you can avoid being an idiot. Goodnight.
'88 Porsche 911 Coupe - Venetian Blau ║ '78 Mustard FJ40 "Uglina" ║ '87 BMW 529i "Maytag" ║ '87 BMW 535is "Vlad" ║ '85 BMW 528i S54 "Minerva"
Ah, the frustration of working on these cars when you are tired. At least you didn't hurt yourself or the painted parts!
Smart move knowing when to call it a night! Better luck tomorrow!
Chuck ------- 70 & 75 911S 96 993 C4S '10 F-150 |
Friend of Warren
You are still just in the minor league of idiocy. If you want to work your way up to the majors, do what I did, reinstall your engine and forget to install the starter ring gear!
Kurt V No more Porsches, but a revolving number of motorcycles. |
just me
I have three repair manuals in front of me whenever I do anything, because I know that if I am left to my own devices I will wind up making a huge mess of it. I also never ever try anything when I am tired... I am too afraid of ending up with a car on my head...
I think knowing you are a clutz helps in this situation
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
That's why I have a Bentley AND the Haynes manual open when I do anything... extra diagrams, pics and descriptions.
I've had situations where the Haynes was correct and the Bentley was wrong. I've found problems with just the Bentley, just the Haynes, and certainly problems using just my brain. Last edited by tcar; 06-10-2010 at 08:11 AM.. |
Great Thread Title..........I don't think there is enough time and space on this forum for all of us to tell our idiot stories......it would be much longer than the "OIL" thread. But thanks to PP Forum we can mitigate our insanity!!!!!!
Great Post.
1984 911 Coupe 2007 Z4 M Coupe 2008 Cayman S 2004 M3-Alpine White(sold) 2002 M Roadster (sold) |
Registered Lunatic
![]() thank God I saw it before firing it up!!!
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up! |
Location: Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
I hope you drank heavily after you were done.
'88 Carrera
you don't really need that aluminum plate.
just me
lol, that's cruel
Decode it.
Unfortunately, John, I feel like I do. I have a sickness (one of several I have) about keeping this car original. That means if Porsche put it on then so do I.
![]() I am curious, however, about what it's really for. My assumption is that its intended to extend the bumper to provide crash protection to the aux oil cooler. My guess is a fender bender in that area without it would more likely result in a BP style oil spill than without.
Decode it.
I was too tired for that. LOL!
Frustrating experience but I'm pretty certain I would have gouged the freshly painted bumper with a screw driver while mounting the license plate bracket AFTER going through your install process. That's the way I roll
Thanks, I need all the help I can get...;] Bruce
87 951 (All stock commuter) 87 951 (Saturday night Special) 77 911S (token tail dragger) 83 928S (engine back in from tear down, interior gutted) ....Grasshoppah |
Agreed, but for whatever reason I put it back on after I repainted my targa's bumper. Man, is it annoying tightening those rubber bellow nuts one lonely flat at a time because of that plate. It's the epitome of what my dad would say represents "a slow boat to China."
Brian
'82 SC Targa '83 SC Cabriolet |
No sleep 'til... BROOKLYN
x038F,
D@#n that's a good looking car. I went through the same ritual a while ago, took the bumper off so I could take the valence off to install my front spoiler. ![]() Quote:
![]() I asked myself the very same question when I took mine off, what is it for? counterweight?
-Orlando- '89 3.2L G-50 '77 S w '79, 3.0L '90 T-3 Syncro 32C #16 |
I think it's there to protect the oil cooler area in case of an impact event.
Brian
Decode it.
BTW, the WHOLE reason I'm doing this project is because:
I feel your pain brotha! - but you paid some tuition in the school of P-cars for a lot of students here (count me of course). Like some others, I have the hanyes and Bentley handy too, with the PET katalog, and along notes from here from posts (Help) like yours.
I'm glad you stopped - that was smart - I've messed stuff up when I work frustrated by my pig-headed-ness. Your car is nice looking and I liked the wheel well details from your other thread.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Helped me already
When I got my car, it was partially disassembled. That piece is one that I haven't before been able to identify. Now I know where it goes!
