TurboRuf's Avatar
Decklid Latch Stuck! Now What?
Ugg… what a weekend. Had the decklid removed to work on the engine and after re-installing, this latch pin is now out of alignment. I closed the lid and when I went to release it…. A small pop and then nothing. Somehow the latch pin is stuck on the latch and I’ve tried giggling/pulling/twisting the lid every way possible and still now luck.
Anybody ever have this happen? Any way to get her open again without doing damage?
85 930 Ruf BTR
Old 06-13-2010, 02:09 PM
nineball's Avatar
did you try moving the lid with the release pulled all the way out? i used a large pair of pliers putting the handle between the pull knob and the body. then i pushed on the lid in various directions, quite hard at some points, until it released. i was applying pressure in two directions, pushing both down and then left/right/up/down at the same time. i spent a good 15 mins doing that because the only alternative is to drill a hole below it to get up to move the release, and i really did not want to do that.
there are tons of threads on this topic here. i know i read at least 10-15 when it happened to me.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 06-13-2010, 03:01 PM
Checked out
McLovin's Avatar
This is no laughing matter!
But like said above, do a search. This has happened to a lot of people, and many have posted various ways they have gotten it undone.
Old 06-13-2010, 03:13 PM
It happened to me last summer. I did a search on here and found quite a few suggestions. What worked was using wire around the pin and pulled it to the side to get it to release. I hope that helps. Good luck.
Chris
Chris
95 993 C2
84 911 gone to to a new home
Old 06-13-2010, 05:29 PM
TurboRuf's Avatar
Thanks! I'll give those suggestions a try.
85 930 Ruf BTR
Old 06-14-2010, 02:08 PM
Pull the latch handle in the door jamb all the way out, put a pair of Vise Grips on the cable against the jamb to keep it out.
The do the above suggestions.
Old 06-14-2010, 04:28 PM
(This thread just reminded me that I still need to work on properly aligning that pin - I just got it close and left it alone.)
To answer the original poster's question - When this happened to me last month, I just had someone pull up on the decklid while I pulled out the release handle in the door jamb. The decklid came up without too much effort.
1984 Carrera 3.2L Coupe, Guards Red
Old 06-14-2010, 05:46 PM
