Another bearing/Brake question
Hi again.
Thanks for the previous input.
OK, so I had to do the Dremmel & Chisel thing to get the inner off. If it's that tight coming off, is the new one likely to be hard to get on with the hub?
Edited to remove stupid brake question........
Old 06-15-2010, 11:06 AM
Senior Advisor
James Brown's Avatar
OK did you heat up the hub first prior to cutting and pounding?
08 Cayenne Turbo
Old 06-15-2010, 02:33 PM
