Rear Speaker Deck Questions
The spec's call for 4x6 speakers to fit the rear of my 1989 Targa via Porsche and Onlinestereo, although Crunchfield shows every model 4x6 speaker as not compatible with the vehicle. It list 5 1/4 speakers as a fit for the vehicle.
I replaced the front speakers last fall and want to upgrade the original speakers in the rear. What size do I need without having to make adjustments to the original settings?
Old 06-15-2010, 07:04 PM
nineball's Avatar
pretty sure they were 4x6 but you may be able to fit some shallow mount 6x9 as well, but that would require a little bit bigger opening in the trim piece.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 06-15-2010, 08:12 PM
Formerly known as Syzygy
Canada Kev's Avatar
I have JL Audio 6.5 inchers in mine. Your targa rear deck may not be tall enough, though? On the other hand, if you have upgraded your fronts, you may not actually need the rears. I didn't miss mine after I did the fronts, but I replaced the rears too, as the existing after market grills were UGLY.
Kevin
Old 06-15-2010, 09:43 PM
I used Kenwood 4x6's in my 83 Targa it was their Excelon brand I think Crutchfield has them
fit perfect sound great.
Old 06-16-2010, 05:02 AM
nineball's Avatar
btw, the 5.25" speakers are what originally came in the doors.
Old 06-16-2010, 05:14 AM
if you want 6X9's you can buy an after market rear speaker. member Tysebold makes them for the coupe, but not sure if they will fit a targa.
best, Paul.
84 R5 T2
04 Suby Outback
"it's a mystery, wrapped in a riddle, inside an enigma" Winston Churchill.
Old 06-16-2010, 07:37 AM
muck-raker
kidrock's Avatar
Originally Posted by 28tbsfan View Post
...although Crunchfield shows every model 4x6 speaker as not compatible with the vehicle.
"Crunchfield"????
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 06-16-2010, 09:13 AM
Born to Lose, Live to Win
ramonesfreak's Avatar
my rear deck speakers were installed by a PO many years ago. not sure what size right now but they are external units...small speaker boxes that are screwed to the deck... looks very 1980's but i like it. i suspect it is because there is no room for the speaker below the deck. i upgraded my speakers inside the speaker boxes a few years ago. not sure if they even make external speakers anymore
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 06-17-2010, 03:54 PM
OttawaDave's Avatar
+1 on not noticing the rears too much if your fronts are in good shape. Pretty sure I've blown my rears - just the other day in fact. Faded the sound all the way to the front, and things sound good enough that I think speaker replacement will drift towards the bottom of the list...
Old 06-17-2010, 05:19 PM
Northern Motorhead
wildcat077's Avatar
I replaced the four speakers in my 89 Coupe a few weeks ago.The fronts are 5 1/4 and the rears are 4x6.
Picked up some matching JBL's at Best Buy and they sound great !
Fit perfectly in the original enclosures ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 06-17-2010, 05:30 PM
Canuck_Targa's Avatar
I have Alpine 6x9 type R on the rear shelf of my 84 Targa, I just had to use 1" speaker spacers to raise them up a bit. They look fine and sound great. I have Focal 5 1/4" in the doors and it is plenty loud even on the highway with the targa top off. I tried to fit 6 1/2's in the door but good 5 1/4's fit better and the performance is very close to the 6 1/2's.
Old 06-17-2010, 05:44 PM
Arkman's Avatar
I was able to mount 6x9 Infinity reference speakers on the deck of my '87. They sound great, but the mounting isn't flush so the speakers are exposed. They have nice looking synthetic cones, so it's not terrible, but you lose the original look with modern speakers in the rear glass.
I also needed to cut the plastic that supports the cone (not much, just a small cut) to fit through the metal oval that the speaker mounts to.
1987 Targa
1977 911s Targa w/'83 SC 3.0 (sold)
2008 Volvo XC70 - family safe transport
Old 06-17-2010, 06:04 PM
nineball's Avatar
there really is no need for rear speakers. when you go to a concert do they put the speaker cabinets behind you?
Old 06-18-2010, 06:30 AM
m110's Avatar
I installed the 4X6 Blaupunkt THX 462 in the rear. They fit without modifying the deck and are the correct depth. The grill was plain black when I bought it but it appears they are flashy now (maybe they still have some older ones). For $40 you can't go wrong and they look stock. I spent more on the door speakers (Hertz) and the rears certainly balance and fill out the sound.
I got the Blaupunkts here
Blaupunkt THx462
1988 Carrera Coupe
Old 06-19-2010, 10:11 AM
80-911SC's Avatar
i agree with nineball to a point, although his system(and mine i have 8's) both have rear seat delete with speakers for the low thump at the back, I run a JBL 720 watt amp I dont recall what 9's running, if you do run rears all they are is fill or a little bump .................
Old 06-19-2010, 12:57 PM
dshepp806's Avatar
,..don't see many speakers on the sides of you at shows, either.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-19-2010, 01:05 PM
nineball's Avatar
i run 8" subs in the back as well but low frequencies, like a sub, are non-directional. basically you don't have to point them directly at the listener.
the door speakers are really not on your side but rather still in front of you. you have to work with what is available, and that is limited in any car. i used mounting cups that angle the tweets to the driver's position.
Old 06-19-2010, 04:08 PM
