speedman's Avatar
rear brake rotor upgrade
I have installed the 964 calipers and 28mm fronts and now I have to attack the rears. Any suggestion on rear rotors
Rick T
Old 06-07-2010, 06:28 PM
wwest's Avatar
Leave them be.
Old 06-07-2010, 07:27 PM
Bill Verburg's Avatar
The easiest is to use '84-89 3.2 Carrera wide m's and their 24x290 rotors
It may be possible to use 964 rear calipers on 24x299 996 rear calipers. I'm not sure yet but have a set on my bench that I've been meaning to experiment w/
Bill Verburg
Old 06-08-2010, 04:37 AM
speedman's Avatar
my plan is to use 24mm x 200mm 964 rear rotors and modify what I need to so they will work. I will let you know if it is possible
Rick T
Old 06-08-2010, 06:48 PM
the 964 rears are 24x299
here's a pic of some rear rotors, from the left 993(24x299, 964 is the same except for a slightly different o/s), 996(24x299) and 911(20x290)
as you can see the o/s are all different which will preclude use on a 911.
The 3 rotors that I know will work on the back of a 911 are
911'69 - 83 20x290
911 '84 - 89 24x290
930 '78 - 89 28x309
I've used the 930s w/ 964 rears
here's a pic of the caliper mods on mine, holes relocated and throat relieved
VCI does it a little differently, they remove the stock mounting ears and convert the caliper to radial mount
Bill Verburg
Old 06-09-2010, 07:53 AM
speedman's Avatar
in your last picture are those 930 rotors? I have access to a full shop so machining is not a problem. I just don't want to drill a hole in the wrong location and hit Hyd. oil. I have put 28mm x 298mm on the front and want the most out of the brake upgrade. I am not doing it for looks since I will be adding a Modified 3.6 soon. If you get too much rotor in the back will adversely affect braking?
Rick T
Old 06-21-2010, 05:53 PM
Right now you have too much front bias. You can,t have too much rotor but you have a larger piston area up front than before . I would use stock 24 mm Carrera rear rotors and the matching Carrera rear caliper . They look almost the same as SC but are wider and have a bigger piston and will restore appropriate front rear brake force ratios . I think still slightly greater front which isn,t a bad thing with good traction.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-21-2010, 07:56 PM
