-   -   Source for ball joint socket tool? (Installation) (http://forums.pelicanparts.com/porsche-911-technical-forum/549335-source-ball-joint-socket-tool-installation.html)
LukasM 04-24-2019 12:39 PM
Originally Posted by azhodge (Post 8369295)
I got one of these 66.5 x 80.0 sockets. seems way loose on the nut. catellated nut seems like a 52.0. But if it work for you then I will give it a try. I would feel better if that big sloppy gap was not around the edge and it was snug. Four teeth also not fully engaged.see pichttp://forums.pelicanparts.com/uploa...1416883188.jpg
I was about to order the cheap tool from Amazon but in that case if it just "kinda" works I would rather find a tool with the right size.
Has anybody found out in the meantime if there is another aftermarket socket that fits perfectly?
blucille 04-24-2019 12:45 PM
I bought one from Pelican user JimmyT, he shipped it immediately and it worked flawlessly, super easy, really well made....and happy to support a contributor to the community
see this thread
http://forums.pelicanparts.com/porsche-911-technical-forum/1008097-removing-ball-joints-w-control-arm-struts-car.html
Harpo 04-24-2019 02:37 PM
Originally Posted by wswilburn (Post 5418306)
The tool is not made of hardened steel. One slip and the points can be rounded. I use a floor jack to press it against the nut and have had success every time.
I agree, you must keep lots of pressure on the socket to prevent it from camming off
piscator 04-24-2019 03:45 PM
Is JimmyT a member here? How can I contact him to buy his socket!
LukasM 04-24-2019 03:53 PM
Thanks for the tip David!
I am already in touch with Jimmy, he is definitely the man for this tool!
I'll PM you his email address so he doesn't get spammed if I post it publicly.
piscator 04-25-2019 04:21 AM
Lukas, thank-you! I'm about to start re-assembling the front suspension and that socket would be a BIG help!
