TSwede's Avatar
Still Struggling
OK... here goes.
I've had another look at the fuse/relay/wiring/wiring diagrams.
The diagram implies that I am looking for brown (earth) and red/white (live) wires to heat the rear window. I can see a red/white wire coming from the relay box in the engine compartment and there is a red and white wire on the multipin plug that goes to the relay box. But I can't find where they go to.
Does the wire in the multipin plug go straight to the window?
Or does the wire coming out of the side of the relay box/fuse holder go to the window?
Either way there is definitely nothing going to the window.
If I can find out which of the red/white wires is supposed to go to the window I can cut it and reconnect it straight to the window. And I assume I can get an earth from anywhere. But the thing is I still can't for the life of me figure out how and where to attach pieces of wire to the window - there is a picture in the haynes manual that is about as much use as an ashtray on a motorbike.... I think something is missing.
Please forward your considerations.
Merry Christmas
TSwede
Old 12-23-2001, 11:12 AM
dickster's Avatar
TSwede
i have to sort mine as well - i had a new rear screen seal put in and the guy cut the wires then rejoined them - they have not worked since.
i'll see what i can find....
merry christmas
richard
Old 12-25-2001, 02:49 AM
TSwede's Avatar
Re: Cheers Richard
Happy Christmas to you as well. Please post all replies to this post to the other topic of mine which begins 'Bad Day Today....' the reason is that someone (I think an administrator) has asked me to keep my posts on the same thread if they are about the same thing. I think I generated the second thread by mistake... it was supposed to be a reply but I messed it up. Anyway, thanks for the reply and I hope to see you on the other thread. BTW there is now lots of useful demister info on that thread now if it is any use to you.
Best regards
TSwede
Old 12-25-2001, 03:09 AM
