No more emissions testing!
Car turns 25 this year, just had my last test yesterday. Talk about flying colors! I am shocked at the numbers for HC and CO; not even close to a problem. CO reading at idle registered ZERO; allowable is 1.2%. CO at "cruise" was 0.3; allowable 1.1%. HC at idle was 14; allowable 220 PPM! HC at cruise was 23; allowable 160 PPM!
I should think the lurking cat bypass out there on the garage work bench will still keep my red car green......... :cool: |
Congratulations. CA used to use the rolling 25yr exemption but now it's 1975 and older. What state are you in?
I can't say. The Governor might get ideas. There is enough money wasted around here already; can't see offering up any such idea....... :D ...knock on wood....
Was it your Corolla?
Actually the Wife has a newer Corolla S and really likes it! |
Cat bypass is weak, go for the SSIs. Go big or go home, right?
I am home....and nope, car is fast enough for me. Cat bypass will be going in when I have the gaskets. :cool:
Unsubscribed. |
Easy Nesslar, it was meant in good humor, not as a insult. I apologize if it was taken the wrong way. A little background of what I was thinking: Quote:
If my memory was better I would have called it a Tercel instead. Cheers, Joe |
I figured as much, no prob. Unsubscribed again... :cool:
| All times are GMT -8. The time now is 09:42 AM. |
