Buying a 911 - rear panel damage?
Hi everyone,
I've been lurking here for a while and have found this site really helpful. I've decided to purchase a 911 and I'm looking at both the 911sc and 911 carrera. I've found a 1986 3.2 carrera (and aside from the potential issue of the 915 gearbox) looks clean (from hi res pictures) and has a very good service history.
Above said. I'm off to inspect the car today but looking at the following picture has me concerned - looks like there's been a repair to the right rear fender? Lines aren't right and welds look messy. Also notice the rivet/bolt is metallic in colour and isn't the same colour as the rest of the body (e.g. looks like it's been removed/worked on).
What do you guys/gals think?
Old 08-07-2010, 03:34 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by chris129 View Post
Hi everyone,
More pics, including close-ups of the concerned area(s).
Also, the sound absorbing material is laying on top of the motor.
We have an '86 since new
pm me as needed.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-07-2010, 05:23 PM
i would think that any significant work there would have resulted in the loss of all the stickers on the back panel ? guess you'll know more once you see it in perso.
Old 08-07-2010, 09:16 PM
Thanks guys.
I inspected it and the fella was a real gentlemen. Although the image looks dodgy in real life it's fine - must be just the lighting.
I'm thinking of making an offer but also keen to look a few more first. See how I go.
Only 'issue' I noticed was that under the car there was no oil leak per say but I could see some oil residue around the bottom left/engine area - not sure what that is? My knowledgeable friend suggests that this is normal as the engines get very hot and some oil spits out but it's nothing to worry about. This is being very fussy, other than that looked great.
Old 08-08-2010, 12:58 AM
I'm about as far from an expert on Porsche engines as possible, but I don't believe it's normal for oil to 'spit out' of one of these engines for any good reason. Have the car inspected prior to purchase by someone expert in Porsches of this vintage. If you post your location I'm sure you'll get shop recommendations from several forum members.
2012 Cayman R - Black/Black
1995 993 - Polar Silver
Old 08-08-2010, 01:09 AM
I found a picture from another 911 3.2 and highlighted where the 'dirty bottom' is (in red).
It was dripping but rather looked like it had thin layer of oil on it.
What part is that? I've tried to find diagrams online but I can't.
Old 08-08-2010, 03:44 AM
Here's the correct part circled that had a thin layer of oil on it.
Looking at other posts on this issue, seems like the answer is 'it could be anything' and 'take it for an inspection'.
Old 08-08-2010, 04:07 AM
Rouxzy's Avatar
When you find one that you really want to buy make sure you have a Porsche knowledgeable mechanic do an inspection. The couple of bucks you pay for an inspection can save you thousands.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 08-08-2010, 04:11 AM
Mo money = mo parts
It's a little hard to determine from the photo exactly what you have circled, but you are near #1 cylinder or the back of the left chain box. Your circle looks like you are at the back of the heat exchanger, which is the source of warm air for the passenger compartment. Depending on the severity and how tight that hose is from the exchanger to the tube, you could get a little odor inside. Oil could be seeping from the back of the chain box where the cam exists, out of the cam tower where the cam exists or from around the rockers. The bottom of the engine does appear to a little "wet" in the photo. It isn't hurting anything, but if oil is dripping on the ground you may want to factor in the cost or effort to reseal the biggest problem areas. My $.02.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 08-08-2010, 04:54 AM
Thanks Tom, Greg
Just to clarify, the picture isn't that of the car I'm looking at - it's one from another thread I just used to highlight the area. I'm trying to organise for it to be inspected.
I ordered four books to read: both of Wayne's books and the service manual (bentley) and also the Zimmerman book. Looking forward to getting stuck into em.
Old 08-08-2010, 04:59 AM
sancho
sancho's Avatar
Have the car inspected and if it works out and you buy it, you do need to show us some pictures.
we loooove pictures
good luck.
sancho
1980 SC targa blue-SOLD
1986 Carrera wide body white
Old 08-08-2010, 05:19 AM
