Second gear problems!
So I am feeling pretty good as my 73 MFI is finally running better (not perfect, however) after a long engine rebuild. And then all of a sudden I can't find second gear AND third feels very strange, like I am in fifth, but the revs tell me I am not. The car is a 73 911t with a stock transmission with 89,000 miles. Any thoughts as to what is going on?
Thanks in advance, Mark |
First thing to do is to check the easiest part and that's the coupler. Did you replace the clutch, pp, etc. during the rebuild?
72 911 Although it is done at the moment, it will never be finished. |
tobluforu, yes I replaced the clutch and pressure plate during the rebuild. When I check the coupler, what am I looking for? (probably obvious, just new at this) Thanks, Mark
Sorry, do a search on adjusting coupler as it may have become loose and slipped or has a hell of a lot of freeplay due to the bushing being worn. If the bushing has any slop, replace. If it looks good, go through the procedure of adjusting the coupler as maybe it will be this easy.
http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 06-22-2010 at 09:26 AM.. |
Max Sluiter
The bushings in the stock coupler are slightly oval so there will be a little slop, even when new. The key is "excessive slop"
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Sherwood |
So I took out the four screws to get at the shifter coupling and laying in the bottom of the tunnel was the bushing, in about four pieces. I will take your advise and replace all three bushings mentioned. The link was a great help and once I get the parts from Pelican, I will be on my way again.
Mark |
Awesome as it's nice when it's an easy/inexpensive fix.
You got that right! I was already thinking "here we go again". Thanks for your assistance, tobluforu.
So I finally got some time to install the shifter coupling bushings. What I can't figure out is how do I get the bushings in? The flange on the bushings seem to go next to the shaft which locks it into place. How do I get the T-shaped metal rod out to put the bushings in?
1990 964 1973 911 3.0 (sold) 1980 911 SC (sold) |
Max Sluiter
Most people use sockets and a vice.
you have to press it out using a couple of different size sockets and a vice.
I installed a Wevo coupling which has 0 play. Great addition.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Thanks guys...it worked, of course!
