typically they come with the battery terminals and since yours apparently did not i don't think there would be any made. if you tell me what size gauge wire and how many i can try to find some for you.
Just ordered an HC800, I'll report back on my install.
Sent from my iPhone using Tapatalk |
http://img.tapatalk.com/d/14/04/03/epa8a4ad.jpg
http://img.tapatalk.com/d/14/04/03/emu6y2up.jpg Just got my battery and box so hopefully I'll have them installed this weekend. It's super light compared to the tank of a battery in there now. Sent from my iPhone using Tapatalk |
nice. closing in on 4 years and the same battery is still running great.
Almost had mine installed but now the groin wire is too short. So much for wrapping this up tonight ....
http://img.tapatalk.com/d/14/04/12/devavyja.jpg
http://img.tapatalk.com/d/14/04/12/regezanu.jpg Sent from my iPhone using Tapatalk |
wow, you car really does have balls! you can pick up a ground wire at your flps for under $10. |
Lol stupid iPhone.
Ya I'll pick up a new ground wire today....it just sucks when you think you are done and then realize NOPE, still more to do. Sent from my iPhone using Tapatalk |
Battery replace
Just took delivery of an '87 911. PO's mechanic replaced the battery some time earlier. Unfortunately he replaced itwith a large and long battery which he rammed into place, breaking the near by AC fan housing, then reattached this fan with duct tape!!
A smaller battery is a good idea! |
Mine is still running strong on the Kinetic AGM
SoCal, that is a clean looking hold down. What brand is it and where did you get it?
The blue tie down was a generic tie down I purchased on Amazon.
Thanks! I have not used Amazon for car parts. I will give it a look
after 3 years of use in a car audio setup and 4 years in the 911 the battery finally gave up. can't complain after 7 years! i installed a new one a couple months ago and all is right in the world again.
This is a nice upgrade, but I did not have the time to do it.
I went with the original huge lunker battery again, partly because my last one lasted - wait for it - 14 years!!! So I bought the same brand of battery, Autocraft from Advanced Auto parts. Craig |
For anyone finding this thread, I just fitted two Kinetik HC600REV batteries ($94 for two on ebay) to my 1970 911E Targa. It was an easy fit and saved lots of weight. It starts ok with one connected but two gives 1200 amps! I made simple lower bracket "loops" to use with the existing brackets. I put some mirror tape under the batteries for insurance (and high G corners :-)
http://forums.pelicanparts.com/uploa...1464623478.jpg http://forums.pelicanparts.com/uploa...1464623528.jpg http://forums.pelicanparts.com/uploa...1464623553.jpg |
It's been almost 4 years and all is well!!! I've also installed in the SC. Thanks nineball.
Derekw - This looks like a great alternative for the early long hood 911's!
Did you use a standard positive battery cable connector for this install? |
No log in since May of 2017. Miss me some nineball.
| All times are GMT -8. The time now is 01:59 PM. |
