Ok I don't know what the proper name for them is. I need the panels that go in place of the fog light cutout on my 1969. You know the ones that are usually painted the same color as the car and goes in place of fog lights?
Anyone know where I can find some? Also are there any seals that go with them? Do the plates bolt on or weld on? Thanks, Dustin
1969 Porsche 912 <- Sold
Example
Stay away from my Member
Porsche salvage yard or swap meet. If there are no swap meets near you, try Carquip www.carquip.com or PartsHeaven.
Be sure you get them with the metal bar thingies that clamps them on. Or...you could always just put some foglights there.
Chris C. 1973 914 "R" (914-6) | track toy 2009 911 Turbo 6-speed (997.1TT) | street weapon 2021 Tesla Model 3 Performance | daily driver 2001 F150 Supercrew 4x4 | hauler |
Well I tired putting some Hella 550s there and they look terrible!
I'm gonna try Carquip but does anyone know what the heck the proper name for these are?
On Carquips sight it says Fog Light Covers not sure if thats what they mean or what. It also says Bumper Bellows? What are those?
Since they're down on the valance, they might be well called "front valance fog light inserts", but just a guess. Bumper bellows are the "accordian" rubber filler between the bumper and fender on '70's and '80's cars.
Or? Leave 'em off, as an opening to duct cold air to the front brakes?
Stoddard has them listed in their catalog:
902.505.055.21.GRV Fog Lamp Cover, left 902.505.056.21.GRV Fog Lamp Cover, right SIC.505.153.20 Gasket material, cut to fit 902.505.145.21 Retaining Strap, 2 req'd. 900.151.006.02 Flat Washer, 6mm, 4 req'd. 999.084.103.02 Hex Nut, 6mm, 4 req'd. 69-73 are all the same. They don't list prices. www.************* BTW, need an owner's manual? There's one on eBay right now! Last edited by cegerer; 12-29-2001 at 06:15 PM.. |
Administrator
Most people want to fill them in, I actually had to hand-cut the holes, for cooling:
![]() (Click for a larger version.)
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Jack? Of course I clicked on for the larger version. Those were hand cut? Did you do it for brakes? Oil cooler? And that negative camber on the front? Gee, what's that for?
Administrator
Cut-out holes, horn grills, removed battery boxes, and headlight socket holes are all for the fender-mounted oil coolers. It's all part of the almighty crusade for lower oil temps on the track.
There are brake ducts, too, but they're strapped to the front suspension. You can see by the rounded outside edges of those (street) tires that the negative camber needs to be increased. At Laguna, Tyson cranked it in another half degree or so.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 Last edited by Jack Olsen; 12-29-2001 at 10:39 PM.. |
Just my $.02
Jack: Where did you get the wire MESH type screens? Are they just local hardware store stuiff or what?
I like the idea of just leaving them open but I have to figure out if I should cut the light bracket out or just put some of the mesh screen wire over the hole.
