zorin's Avatar
Power Seats - two fuses?
Hi,
I have a '79 Targa. The driver side power seat buttons no longer work. Passenger side buttrons work OK. I know for sure that fuse 2 (AC) controls passenger side power seat buttons since when I removed it the buttons stopped working. Does the driver side power seat switches use a fuse other than AC fuse? All other fuses seem to be OK. What could be the problem then? I checked the switches for power with voltmeter, no power.
What amp is the AC fuse supposed to be?
Is there a way to move the seat manually? I need to get the seat out but I cannot unbolt it without moving the seat.
Thanks.
Zorin
'79 911 SC Targa, 3.2L Carrera engine - Zenith Carbs - 36mm vents, Lightweight Flywheel and PP
'00 BMW 540i - Sports Package (The Beast)
'99 LandRover Disco
Old 07-05-2010, 06:17 PM
