Senior Member
ohecht's Avatar
Dumb question - turbo tie rod ends
I just ordered a set of replacement ends for my turbo tie rods from our host, and have what's probably a dumb question...the new rod ends came with white plastic caps over the rubber boots. I assume these are some sort of protection before installation and should be removed before installation, but wanted to double check with others that may have seen these. They look almost tough enough to act as some sort of spacer or protection, so I just wanted to make sure...
Thanks in advance,
Olivier
Olivier Hecht
1982 911SC
Old 07-05-2010, 03:41 PM
burgermeister's Avatar
Just protects the threads and the taper of the ball stud during shipping. Remove before install.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 07-05-2010, 04:03 PM
Senior Member
ohecht's Avatar
Got it...thanks.
Olivier Hecht
1982 911SC
Old 07-05-2010, 05:18 PM
