911cabby's Avatar
Soft top rear window question-
After 1 month of ownership I just noticed that the rear plastic window half-zips down on my cab- am I suppose to be unzipping (the window that is) before lowering the top?
What the purpose of the feature?
Thanks for your help!
____________________
1987 Carrera 3.2 Cabriolet
Triple Black- 18" Staggered Victor Equipment
Momo Wheel- Magnflow Exhuast
Old 07-27-2010, 06:25 AM
muck-raker
kidrock's Avatar
I believe it is better for the longevity of your top and window to release the top a bit before zipping or unzipping the window.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-27-2010, 06:37 AM
dfk911sc's Avatar
Always unzip. After i release the tension from the latches unzip and before I latch the top re-zip. This will prolong the life of the window and help prevent creases. Never in the cold. I read somewhere that the additional benefit is ventilation when the sun is beating down on you you could run with the door windows down and the back window open.
Dan - schnell fahren, leben hart
83 RoW 911 SC Cab
SCWDP Conspirator
C.R.A.P Gruppe Registry #27
Old 07-27-2010, 07:32 AM
bonkers's Avatar
Originally Posted by dfk911sc View Post
Always unzip. After i release the tension from the latches unzip and before I latch the top re-zip..
Ditto
Carrera 3.2 - "Faster, Stronger, Better"
Old 07-28-2010, 10:40 PM
