pjv911's Avatar
Send a message via AIM to pjv911
What is this ?
Got this from a german auto repair shop here on long island. Says becker on it so it must be radio related. The guy has about 20 p-cars all early 911 or 356. I go there from time to time looking for goodies. Today I bought a truck load of parts which I hand picked (I scored) . In the piles of parts that were allready dismanteled I found this. Could anybody name the part and its correct vintage. Its possible its not even a porsche part but should be.
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 12-27-2001, 06:11 PM
Eric Coffey's Avatar
Question Thing-a-ma-jig
Could it be an old A/C-to-12V power supply (converter) for bench-testing radios?
Old 12-27-2001, 07:29 PM
pjv911's Avatar
No its definetely for a stereo since it has speaker outputs and i noticed it says autoradio on it under the name becker. Im quessing its a early factory amp from a 911/912 but im just guessing.
Old 12-27-2001, 08:00 PM
Senior Member
Doug Zielke's Avatar
Take the cover off. Does it have vacuum tubes?
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 12-27-2001, 08:06 PM
APKhaos's Avatar
Doug is hot on the trail.......
In the [very] old days, the radio console contained the volume, tuning, and power controls only. The rest was too darn big to fit in the console. What I think you have there is the 'remote' side of one of these early radios. It contains the RF stages and audio amplifiers, all of which were hollow state technology - vacuum tubes.
If you can find a becker model number anywhere, the 'men in plaid' might be interested - many early 356s had these ripped out in favor of the later on-piece transistorized units. This might be a nice find for the true 356 resto fiends.
Tony K
'89 944T
944 SuperCup Champ 2004 & 2005
'85 Carrera - Sold [sob]
TrackVision
944Cup
The 999 Site
Old 12-27-2001, 08:12 PM
pjv911's Avatar
Also on the becker sticker it has the word UMRICHTEN and the # 286075. Although im not sure about the 8. Here are some more close ups. Yes there is glass vaccum tubes and it also very heavy.
Old 12-27-2001, 09:04 PM
pjv911's Avatar
Heres a pic of the sticker
Old 12-27-2001, 09:05 PM
Senior Member
Nice museum piece!
Any electronic gear you find these days containing "bottles", is worth keeping for the sake of nostalgia, if nothing else. Don't expect it to work...the electrolytic capacitors are probably well past their prime.
Heavy?
Sure...the power supply and audio output transformers would be huge by todays standards.
Beefy iron cores and copper windings.
It likely has an inverter section to convert 6-12vdc to the higher AC voltage the bottles require. More tubes and transformers.
The chassis may be made out of copper sheet as well (for heat disipation and freedom from E.M.I.).
Old 12-27-2001, 09:24 PM
You guys are correct. The older radios have two parts. The front portion is the rx of the radio. The back portion that you have is the amp portion of the radio. It bolts to the rx with a couple of metal straps. Depending on the vintage many of the early amps operate on 6V or 12v. As far as value its not worth much, as Doug stated the caps are probably dry. Now if you had the front end (the rx) to it and if it was working it would be worth $100.00 PLUS (to someone like me looking for an old tri-band 6V for my 356)!!!
gary
ghanlon
Old 12-27-2001, 09:40 PM
Wink
German experimental Flux Capacitor?
Howie
79SC
Old 12-27-2001, 11:32 PM
what is it
sounds like that is what it is. Call ford electronics in fullerton. I worked with one of the sons he told me that they had tons of tubes for old electronic stuff...Maybe some help
Old 12-28-2001, 12:41 AM
