Ac condenser/hose connectio issue
Looking to add 3rd condenser in line from lid to one up front. Question is how do I deal with fact that typically condensers "in" connection is not the same as out, I.e. 8 and 6? I'll run the 8 from the rear deck lid to the new condenser but how do I deal with fact that it's out is a 6 but continues onto the front condenser which is an 8.
Tia
Old 07-23-2010, 08:05 AM
Go online and look at Ray's auto air conditioning and look for step up fittings for #6 to #8. You should step up the fitting so you have a #8 line up to the front condenser, which by the way has a #8 hose with a step down fitting for a #6 nipple.
Save yourself the headach of adding a third condenser, replace all existing hoses, the drier, clean out the evaporator, install a new Sanden 507 and charge it with R-12 or an 80% charge with HFC 134
Old 07-23-2010, 12:52 PM
